Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side, GSS22UFMWW, water dispensor does not work, when I try it water leaks from the bottom of the frig. I can hear it pumping.
  • 5,081 Answers
Turns out there is actually a small drain hole on the bottom of the freezer where condensation and such goes. Take out your bottom drawer/shelf and look in the back of the freezer.
Pulled out the bottom white tray that is under the wire shelving and at the back of the freezer is a small hole. Pour in a cap full of bleach and then 1 cup of boiling water. There can be condensation builds up and clogs the hole.
Posted on Sep 09, 2010
No water from dispancer
Could be the water valve it should be a double soleniod, one for the icemaker the other for the water dispensor. Have someone push the dispensor button while you listen at the back of the fridge. It should be located at the bottom right corner, even if youcan hear it, it may not be opening. You can remove the plastic line that goes to that side of the valve and have someone press the button again to see if any water comes out. If it does you may not have pressed and held the button long enough to fill the resevoir that is located inside the freshfood compartment.
Feb 24, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from dispensor in door.
Ice supply line is frozen in the freezer door. Using a hair dryer with the door open you have to thaw the line. This will take time but this will fix.
Feb 01, 2010 | GE GSS25LGM Side by Side Refrigerator
Our water dispenser stopped working we can hear it click but water will not come out?
At the bottom of the freezer door ( remove the kick plate by removing 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If frozen , GE has a water dispensor heater , pt # WR49X10173 , to keep this from happening again . Also , by turning the dispensor light on , for several hours , so it will heat the spout , has worked for several people .
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
The ice dispensor and water dispensor on my GE Profle side by side refrigerator quit working.
Did you check the filter ? If it has been a few years, the filter can be clogged. Also, the water line connection valve may be internally blocked. If it is a tap-valve I suggest you turn it fully closed and then reopen it; this may break free any deposits that have built-up and clog the small opening. But before you reopen the valve, disconnect the line where it attaches to frig and let the first quart of water flow into a container to fluch away any particles before allowing it to flow into frig system.Can also be that the inlet selenoid valve or its wiring connections and switches are not working. You must hear a click sound when you touch the dispensor handle for water. Good luck, Macgivor
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator wate leak
Usually at the bottom outside of door (near hinge) is where the waterline will become loose or crack. Otherwise, I would have to look at it.
Apr 21, 2008 | GE Profile CustomStyle PSI23NGR Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
78 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
