Question about Crosley CDG6000 Gas Dryer
How do i hook up a 4 post plug to a 3 post plug
  • Crosley Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Sep 10, 2010
  • amy pittman
    amy pittman Oct 17, 2013
    what the color wires go to on the back of the dryer.
We just moved and this house has a 4 prong dryer plug and our last house had a 3 prong dryer plug. We bought a new plug and hooked it up as it says and still nothing. Any help would be much appreciated!
You may have inadvertently incorrectly wired the dryer power cord. The following link epxlains the differences between the 3-wire and 4-wire configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Make sure you have the wires connected properly at the terminal block. Pay particular attention to the difference in how the ground and neutral wires are connected. If you have any questions, please post back and let me know. I hope this helps you.
Dec 01, 2010 | Roper REX4634KQ Electric Dryer
NEED TO KNOW HOW TO HOOK UP A 4 PRONG CORD TO DRYER WHAT COLOR GOES WHERE
The following link explains how to properly connect a 4-prong power cord on your dryer:
If you have any questions, please post back and let me know. I hope you find this helpful.
Oct 07, 2010 | Kenmore Dryers
New plug changed from a 4 wire to a 3wire,won't run.
You have 3 lugs to hook up to. right lug gets red or black, left lug gets red or black. Center lug gets white. you can also hook green wire to center with white. Or hook green to the screw for the lug cover. What you did is correct.
Jun 14, 2010 | Frigidaire GLEQ332A Electric Dryer
How do i figure out what post my spark plug wires
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway.
For the 2.5L (4-Cyl):
Firing Order:
1-3-4-2
Cylinders:
(back of engine)
1------2------3-------4
(front of engine)
Distributor:
......(back)
......1......3
(+)..............(+)-screw
......2......4
......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Feb 15, 2010 | 1993 Plymouth Voyager
The 3 prong plug that plugs into the wall has three wires at the end and need to know where do i hook those up too. its a kenmore dryer model #110-64852-400. the ser # is mr2206786
The following link explains how to correctly install a 220 VAC applaince cord on your dryer:
There is a difference in how the 3-wire and 4-wire configurations are terminated. Follow the wire color codes under the 3-wire configuration.
Jan 14, 2010 | Dryers
How to hook up heater motor to fan switch
The 3 resistor post should be the first 3 lower speeds on the switch. The high speed should be direct. Hope this helps.
Oct 25, 2009 | Chevrolet Camaro Cars & Trucks
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Trying to hook a 3 prong hook up with 4 prong cord how do i do it?
A 3 prong plug is for 240 volt (hot-hot-ground) the 4 prong plug is for 120/240 volt (hot-hot-neutral-ground). If your device requires a 4 prong plug, it is not a good idea to connect it to a 3 prong circuit (you will create a possible lethal electrical condition). If your device requires a 3 prong connection, a 4 prong cord can be used by not connecting the neutral (white wire). If you have any questions, let me know.
clarkco
Mar 31, 2009 | Maytag Dryers
Crosley CDG6000 Gas Dryer Logo
99 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
