Question about LG WM-2077C Front Load Washer
THE DE ERROR CAME ON MY WASHER WHAT DO I DO/ - LG WM-2077C Front Load Washer
    President:
  • 1,932 Answers
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening
If happening in mid cycle power of the unit and remove the power cord and wait for 5 mins.Then plug it. Check whether the door opens if not you require the service people
Check anything is caught on the washer door.
If you passed it they door may not open if the inside water is warm.It is a safety feature.It unlock after sometime
Thank You
Posted on Sep 09, 2010
DE error code on Kenmore HE front loading washer
that is telling you there is a DOOR ERROR sometimes the magnet slips out of place or the wire comes loose .
Dec 21, 2016 | Kenmore Washing Machines
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
What is LG washer code dE?
The dE error code indicates a Door Error. The washer thinks the door is not closed. Have a look at these...
1. There should be a plastic finger on the door that pushes the door switch when the door is closed. Is the plastic finger broken off by chance?
2. The switch itself could be bad.
3. If you overload the washer, this could cause this error code also.
Aug 10, 2014 | LG Washing Machines
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Have a de error so washer won't work how do i fix?
A DE Error Code is indicative of a "Door Error"
Check in this link the LG procedure: lgknowledgebase.com/kb/index
Hope helps.
Aug 11, 2011 | LG WM-2277HW Front Load Washer
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
Washer will not fill . error code 'de' pulling up. whats de code?
Unfortunately you do not mention what make and model!
However 'de' seems a common indication in many washers of Door Error. Possibly either the latch or the door close sensor is malfunctioning and will require attention.
Hope this helps,
John C
Mar 02, 2011 | Washing Machines
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
LG WM-2077C Front Load Washer Logo
152 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
