Question about Pool & Spa
Wont reach temperature - Pool & Spa
  • 990 Answers
Bad heater or temp sensor.
Posted on Sep 09, 2010
Everything seems to be running but no air is coming through the vents
If the unit is on heating mode, the inside coil has to reach a predetermend temperature before the indoor fan will start. If the system is short of refrigerant the coil wont reach the temperature and subsequently the fan wont start
I hope this was of some help to you?
Good luck
Jun 09, 2015 | Heating & Cooling
Why is the oven bell not ringing when it reaches the set temperature.
If the temperature reached at it operating temperature and oven display doesn't showing how much time left for ready screen then most probably its IO board gone.
I have seen many cases like this, and replacing IO Board fixed the problem.
Please rate my work
Thanks
Sagar
Sep 19, 2014 | TurboChef TORNADO Electric Oven
Brakes arent releasing red turning red hot
Brass begins to turn red when it reaches the point of annealing. The temperature Brass must reach before this point ranges from 450 degrees Fahrenheit and higher.----------------------------------------------------------------------
Multi-Diag
Dec 04, 2012 | Cars & Trucks
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
My coolant fans wont spin. they work when tested with the battery. changed sensor and all fuses/relays are good. What could be making the fans not spin?
They only spin when your coolant system reaches a certain temperature. If you have a lower thermostat installed or a malfunctioning one that stays open and never lets your cooling system reach it's recommended operating temperature, then they will never spin. Your vehicle may be running too cool.
Feb 15, 2011 | 1999 Chevrolet Malibu
Refrigerator wont shut off
replace the cold control and prob should be over .. mm
Jul 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fan relay not working , fan keeps going on and off wont stay running
One of your fans works off the coolant temperature sensors input and will only engage when the coolant temperature reaches and/or exceeds a certain preset degree. The other runs off of your a/c compressor and when it engages so will the auxiliary or secondary cooling fan. Start the engine cold, turn on the a/c and listen for the secondary fan to engage then as it warms up listen to see if the primary fan engages. when it reaches running temperature. Please rate me on this answer.
Jun 08, 2010 | 1998 Pontiac Bonneville
F1 error code -wont advance after it hits wash cycle--heater ohms out ok-any solutions?
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective
Feb 02, 2010 | Asko D1776 Built-in Dishwasher
Gas dryer wont trun off after drying
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 08, 2009 | Dryers
Air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Jun 14, 2008 | Kenmore 72055 Air Conditioner
Pool & Spa Logo
49 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
