Question about Homelite Garden
Yes i have a hb-100 blower and when i hit the primer ball it pushes air out of the gas line but it does not **** any gas up the line back into the carberator??
  • 252 Answers
Sounds like the primer purge valve is faulty
but check the fuel filter and lines anyway for holes / perishing
could also be needing a carb kit installed particularly if been sitting around
might pay to fit carb rebuild kit for this machine
carb id # is stamped on the carb ie c1q or c1u ####
parts needed should be in the kit
your local outdoor power shop should be able to organise this
cheers
Posted on Sep 09, 2010
What else should i try
Make sure lines are connected correctly. On the back of primer it is stamped In & out
Jul 25, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Echo pb 251 leaf blower leaks oil
You need to check your gas line and the primer ball itself and make sure you don't have a split in the lines or in the ball, also check the fuel filter in the gas line to ensure it is not plugged up.
Apr 24, 2014 | Echo Pb-251 Leaf Blowers
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
Primer bulb not filling
Yes, I think the gas cap may be clogged. The gas cap must be able to breath, otherwise this vacuum will occur. Try starting your trimmer and when it starts to choke out, loosen the gas cap. It should get air back in the tank, then and keep running. If this works, clear the hole in the gas cap, or purchase a new one.
Jim
May 03, 2009 | McCulloch 26cc Gas Blower Mcb3208
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
Apr 12, 2009 | Homelite Consumer Products MightyLite...
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
Gas line connections
The thicker of the two lines goes on top nearest to the primer ball
Mar 21, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Both gas lines are dry rotted off...
Sorry about the delay.
Problem solved, I hooked up the lines (very important to get a drill the size of your new gas line, it aids in sealing the tank, thus providing a good seal for the prime).
The thing in the bottom of the tank, attached to the line is a filter. It is available at any small engine shop).
Once I hooked up the lines and hit the primer ball a few times you can see the fuel moving, you will know, because you will see which way it flows through the lines. The other line is just a return line into the tank.
It is the same on generally any 2 cycle blower or weedwacker motor.
Dec 21, 2008 | Poulan Featherlite Gas Blower, with Low...
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
75 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
