Question about MidiLand MLi 170 Computer Speakers
I simply have no sound. my speakers are hooked up but it says there not detected
  • 27,725 Answers
Control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Posted on Sep 09, 2010
How do you power up the sattelite speakers without the subwoofer?
Depends on the type of sound system. Some require you to hook up to the subwoofer then the subwoofer to the sound system, others are just a direct line in to the sound system (in which case simply un hook the sub woofer. If it requires hook ups to the woofer, see if you can turn the volume down on the woofer directly.
May 29, 2015 | Audio Players & Recorders
I hook up my speakers to my computer but no sound device detected i get a humming sound though?
Without getting into a vbak and forth with you about all the details of your PC, you should use a search engine to find high-level advice on how to get your sound device going (sound card). Until THAT happens speakers will not work.
"hook up my speakers computer no sound device "
Aug 01, 2011 | Audio Players & Recorders
Just installed the deck and it works but there isnt any sound
Assuming you have checked the obvious mute button, all aftermarket decks have a ground fault system integrated. If one of the leads to the speaker wires is touching ground, then it will shut off all outputs to the speakers. This is easily checked with a volt meter or a speaker itself, whichever is more readily available. Disconnect all wiring for the speakers you just hooked up and simply hook up only one speaker to any of the sound outputs. Do not let the other leads touch anything. Turn on the radio and if it works, you need to chase a speaker wire that is touching ground, plug in one at a time and go from there.
Jul 17, 2011 | Kenwood KVT-514 Car DVD Player
Unhooked everything from computer to move, now i have hooked speakers back up, and there is no sound.
Most of the time that problem is that they are plugged into the wrong port. Make sure that they are plugged into the green port on the PC or the one with a logo of sound waves with an arrow going towards the center or simply a speaker logo.
Best of luck
May 25, 2011 | Dell AS500 Sound Bar Computer Speakers
No sound
Make sure the speaker are plugged into the "audio out" ports. Black negative, red positive.
If a dvd players or other system is hooked up, the speaker should hook into that unit, then the unit is hooked to the auxiliary port(s), or the proper ports for each unit: ex: cd/dvd should be plugged into vd/dvd; same for vcr, game system - auxiliary is for pretty much any unit not listed on the backing of the receive - however, some units will still work while plugged into the ports other than auxiliary.
Make sure the receive is selected to the desired device.
If you simply have the speakers plugged into the speaker ports, make sure the speaker themselves are still good - try hooking them up to another source such as a a dvd player equipped with surround sound or speaker adapters that will suffice your speaker wiring.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 28, 2010 | Onkyo TX-SR606 Receiver
Speaker is not detected
If you are connecting a 5.1 surrround sound rather than 7.1, have you connected the surround speakers to the surround left and surround right rather than surround back left and surround back right?
Nov 11, 2008 | Onkyo TX-SR703 Receiver
A friend hooked extra speakers to my system and now the speakers have no sound what have he done/
He probably overloaded the system...it is rated for a specific resistance and adding extra speakers can ruin the speakers or the system or simply not play. I recommend researching the rating or simply disconnecting the extra speakers.
Jul 21, 2008 | JVC AM FM CD DET FACE CAR STEREO
No sound
Sounds like you have missed the wire which connects them to your pc (or to each other)
Mar 21, 2008 | Logitech X-230 Computer Speakers
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
MidiLand MLi 170 Computer Speakers Logo
80 people viewed this question
Top MidiLand Audio Players & Recorders Experts
Fernando Torres
Fernando Torres
Electro Med Services...
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
