Question about GE Ovens
HELP!!!! GE Model PCB975SP1SS I have a GE electric only 3 months old...Sears just replaced the entire ectronic control counsel and circuit board. As well they installed a new motor for the convection oven. When I plug in the stove...i get an error message F810. The control panel doest even allow me to do anything or even turn it on. Can anyone tell me what the problem is. Angry in Ajax
  • 101 Answers
I wuold call ge service their techs are trained on ge products only ,it is covered by warrenty
Posted on Sep 10, 2010
The plastic cover on our GE Oven Model JKP70W started separating and then came off, leaving it very unsightly. Can this be replaced or does the entire control panel need to be replaced? Any similar
Call GE - 866-622-6184
There is a campaign to replace that part as they are defective.
They will send you the part for free, but charge you $200 to install it. The install is not too hard. Make sure you power off the oven when you do it. Instructions are included.
May 07, 2012 | GE JKP70 Electric Single Oven
GE Profile Wall Oven Circuit Board
http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
F30 error code
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Getting a f2 code on GE oven model JKP13
Control senses oven temperature above 615F-630F (F-2)
If actual oven temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jun 13, 2009 | GE Profile JTP18 Electric Single Oven
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
Overlay Panel bubbles up!
I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
Jan 02, 2009 | Ovens
F7 Failure Code
Hi markw421,
No you do not need to pull the entire oven. If I knew the model number I could give you specific instructions. You can go to www.partselect.com and put in your model number and you will find diagrams that will help you open up the beast.
Regards,
Powerman
Oct 30, 2008 | GE Profile JTP18 Electric Single Oven
The GE Profile Advantium SCB2001KSS started beeping and displaying error code F3. I was able to set the time after holding one of the controls in for 3 seconds, but it reverted to the beeping and F3 error...
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Oct 19, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Unit has no power.
Aug 22, 2007 | GE ZSC2001FSS Advantium Electric Single...
Ovens Logo
107 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
