Question about Zenith Televison & Video
I have a Zenith VRL427OHF VCR. It will play Tapes great, but when I have incoming video ,it is "off", like it it needs tracking. This happens with component or coaxial input. I have tried all combinations of input and out. I recorded , and played it, and that doesn't work. Any Help would gratly be appreciated. Thanks in advance, Sincerely; Brian Weber
  • 3 more comments
  • bweber137 Sep 09, 2010
    Thanks for your reply. I can solder, but but my knowledge of VCR repair is limited. Is there an easy way to describe where I would find the input switching area. And what is the PCB? I apolgize for asking, but would like to fix the VCR. I appreciate your help.
    Thanks in advance
    Brian W.
  • bweber137 Sep 10, 2010
    Sincerely;Brian W.
    There is a horizontal line abpout half way up on the screen. It does this with it on AUx, and when I have it on Ant IN, as well. "Silverdragon sais it could be a bad solder joint in the input switching area, or PCB. Iam asking where is the input switching area, and the PCB on the circuit board?
    Sincerely; Brian W.
  • bweber137 Sep 11, 2010
    Yes when I record something, it plays back garbeled or messed up. But even when I have Incomining video through the VCR ,without recording, it is messed up. Could it still be the record or erase head?
    Brian
  • bweber137 Sep 12, 2010
    Thanks for the reply krbjmpr : Someone suggested bad solder in the video input switching area. How do I tell if it is abad solder? And I don't think I could troubleshoot apower supply. Sorry for the inexperience.
    Brian W.
  • Zenith Master
  • 17,130 Answers
Please understand that the VCR tapes having a control track on the lower portion of the tape.
The control head senses the track and sends the pulse to the servo section of the VCR for switching the video heads.
If the alignment of the control headd is off, if the alignment of the tape positioner ont he drum is off, if there is dirt in the drum or rollers or dirt inthe control head( control and Audio head), this is possible to have the video not responding to tracking.
So clean the control head( the head near the pinch roller) and make sure that the tape is not pulled off the track.
If this is alright then the fault is within the servo section.
The possible control siganls are not processed and switched here with the help of the drum and capstan input signals.
This IC can be defective but you must be able to test with an oscilloscope to trace signals to confirm.
Posted on Sep 13, 2010
  • 1,476 Answers
Bweber137,
You need to clean the heads on your unit. If the heads are dirty the unit will play tapes fine but will not record satisfactorily. I have a tip at http://www.fixya.com/TipsAndTricks/thanks.aspx?thid=5970839 which expains the process in detail.
Thanks for using FixYa and for the great rating!!
hardrocko
Posted on Sep 12, 2010
  • 905 Answers
Hello Brian,
Your record head is clogged, or the erase head is not working like it should. If the record head is clogged, it is beyond the scope of the cleaning products available on the shelf.
Call around to a local repair shop, ask them what a "Tape Path" cleaning would cost. That will also force them to visually inspect the erase head, and perhaps save you a service charge.
Posted on Sep 11, 2010
  • Sheldon Dedek Sep 12, 2010
    No, if you are feeding video through the VCR, then to the TV, you should see what is originally playing. The VCR should not be affecting the picture at this point.
    This is now pointing to an interference problem. In your other comments (I can't see other solutions), you mention that you are able to solder. Are you able to troubleshoot a power supply? I suspect that a filter section is not doing what it is supposed to, and is introducing noise into the video path.
  • Sheldon Dedek Sep 14, 2010
    Looking for bad / cracked / cold solder joints is hard to describe in words, but here is a some material to take a look at. http://www.dummies.com/how-to/content/so...
    If you do find a bad joint (of whatever type), consider taking it to a service shop for the repair. Your VCR will be full of components and boards that are going to be sensitive to static discharge and stray voltage. Most consumer soldering irons don't offer protection against this.
    It may be time to bite the bullet and take the VCR into a service shop and let them charge their diagnostic fee. Then you can make the decision to repair it, some shops apply the diagnostic towards repair as well.
  • Zenith Master
  • 5,807 Answers
Could the Input color system be the same as your VCR?
Have you tried connecting your " Incoming Video "
direct to TV , just to see if it is OK?
What incoming video are you referring to?
Have you tried a camera or other source ?
( if you have one? )
Posted on Sep 10, 2010
  • 6 more comments
  • Rommel Cana
    Rommel Cana Sep 10, 2010
    More details on the picture you are having,
    Is it having color?
    Is it not having color and rolling?
    or it is having none at all
  • Rommel Cana
    If there is none at all, insure that you are set to AUX
    like sample image:
  • Rommel Cana
    Rommel Cana Sep 11, 2010
    If your problem is a horizontal line, then your problem on the switching
    input could be later after you can view full screen on your TV.
    If you have open the unit look for the yoke
    then follow the four ( 4 ) wires going to the main board,
    near to it , you will see an IC mounted on a heatsink
    have that pins ( IC ) resoldered first , then post
  • Rommel Cana
    • have a continuity check on the two coils on each
    ( Vertical , the other pair is for Horizontal )
    How to test for Continuity
    You may need to have:
    a Multimeter
    How to use a multimeter
    And a lot of patience
    And may need soldering tools
    How to solder boards properly
    • When these is done , and yet still same problem , then you
    may need to go down further to the main board
    • Check on the connectors ( On most it is yellow and green wire,
    yours might be different ).
    • But that would be less likely although, you are having one
    line of the screen.
    • Further ( after tracing ) it will lead you to the vertical Section
    another sample image:
    sample Vert IC
    • You may need to replace it , if replacing capacitors,
    double checking resistors value are OK,
    and after resoldering it properly wont still work.
    • Vert. Osc is the heart of the Vertical Circuits and
    most can be
    found inside the Jungle IC,
    include some resistors in probing,
    too.
  • Rommel Cana
    additional info:
    • the other two wires from the yoke,
    goes to the horizontal output transistor
    that is connected to the
    Flyback
  • Rommel Cana
    But have you tried connecting your TV to other sources like switching to
    Ant or a DVD player perhaps just to see if your TV is OK.
    And if it is OK,
    then your Video Circuits from VCR is bad , could be a bad op amp IC
    not the erase head and record ,
    you should see it clear on your TV even without recording
  • Rommel Cana
    Rommel Cana Sep 13, 2010
    Before opening anything , ( to be safe )
    I need to know if you have a problem when that player is not playing,
    I mean there is a complete raster on your screen ,
    even on either one of your TV inputs.
    There are hazardous voltages inside , if you would open your unit,
    even if you have the tools and equipment.
  • Rommel Cana
    I understand if you cannot see my former post.
  • Zenith Master
  • 12,061 Answers
I suspect you have a bad solder joint on your input switcher IC, or on the Plug's where they join onto the PCB, in that area, this sounds like a bad solder joint, somewhere in the Input switching section.
Also check, all plugs and connections are tight, especially the center pins.and earths.
Posted on Sep 09, 2010
The menu screen displays but it wont play tapes
Do the tapes play in the machine, but you don't get a picture. Or do they not even start to play?
If they play and you don't see a picture then you need to clean the VCR head. You can get a tape head cleaning tape for this.
If the VCR won't play a tape at all, please describe in more detail what happens when you insert a tape for playback and I or someone else at Fixya will help you further.
Nov 16, 2015 | Zenith Televison & Video
The VCR is completely off track.. Does anybody has any solutions?
If by "off track" you mean it cannot track an image on the tape, it may just need cleaning. The heads, head drums, guides, and rollers in the playback mechanism require cleaning on a regular basis and, if they are not cleaned regularly, oxide particles and dirt accumulate to the point that the VCR is no longer able to play tapes.
Although automatic head cleaners are available, they're more for maintenance, and if it isn't playing tapes anymore it's beyond that. I would recommend taking the VCR to a repair shop for cleaning... shouldn't cost very much, and it should solve your problem. (Let's hope that the heads aren't worn down... bit more of an issue.... but try the cleaning first.)
Once you have the unit running again, buy an automatic cleaning tape and use it every few plays.
May 21, 2015 | Panasonic DMR-E75V DVD Player/VCR
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Hi. I am using a Panasonic 4 Head Hi-Fi Stereo Omnivivion to convert VHS tapes to DVD. It appears that the tracking needs adjusted, but I do not see anything on the unit to do this. Can you help?
Normally the tracking control is on the remote control. Some models do use the up & down channel selectors on either the remote or the front panel of the VCR. If you don't have the remote, the best way to test if it is these controls on the front panel, is to start a video playing a hold down the up or down key and watch to see what happens. If they operate the tracking, the tracking should go way off (do it on a video that is tracking well when first playing).
PS don't forget to clean the video head every so often (Servisol video 40 spray is best for that).
Jan 09, 2011 | Panasonic PV-V4523S VHS VCR
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Feb 11, 2008 | Zenith VRB420 VHS VCR
Video noise at bottom of screen
Try adjusting the tracking on your VCR. This symptom would typically be caused by a slight tracking error in your VCR or video heads that need to be cleaned. Your Zenith TV may be a little more sensitive to video synchronization problems than your other TV is.
If VCR tracking adjustments have no effect on the symptom, then the problem could be in the TV, but I'll need more details to assist you with troubleshooting. For example, how do you connect the VCR to the TV?
Jan 27, 2008 | Zenith B27A11Z 27" TV
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Can hear crackling or spitting sound when selecting HI-FI
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes. The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and other kinds of damage.
Mar 08, 2006 | Zenith VRA421 VHS VCR
Televison & Video Logo
61 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
