Question about Ricoh Office Equipment & Supplies
I have 2 problem for Aficio 3045 i) the copier alway show toner sign on when i fill the toner or change the developer also the same. ii) B5 paper cannot be use,always jam when i using drawer or multiple bypass.
    Problem Solver:
  • 3 Answers
For solution ricoh af3045
Try check cover toner while fix wrong or right,maybe it is sink in toner
Posted on Jan 22, 2012
  • 155 Answers
Most of this add toner problem came from the toner hopper, this need to be checked by a technician to fix the four plastic mylars to see to it that they are attached and properly scrapped the toner. next is the B4 fist do you set or is the right paper size is set on the drawers? what is the jam code so we can see if were is the fault of the machine?
Posted on Sep 10, 2010
FAINT COPIES RICOH AFICIO 2035E I have been experiencing the following problem for a while but it clear if I perform the following solutions. When I ADD TONER MANUALLY add toner in the developing un
YOU CAN TRY THIS.
AFTER YOU DO MEMORY CLEAR THEN YOU HAVE TO FIRST DO FORCE TONER SUPPLY UNTIL THE IMAGE IS GOOD ENOUGH AFTER THAT RUN THE ID SENSOR INITIALIZE. I HAVE AN EXPERIANCE A FEW YEARS AGO AND I DID THIS WAY AND ITS OK. ( MUST CLEANS THE ID SENSOR BEFORE DO INITIALIZE)
Nov 28, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Error code sc450
450
D
Feed Development Motor Error
•???? Motor lock caused by overload.
•???? Motor driver defective.
The PLL lock signal remains LOW for 2 s while the feed development motor is operating.
May 21, 2014 | Ricoh Aficio 3045, 3035 Kit
My copier machine Richo Aficio 3045 do not supply toner
could be devlp powder is bad. replace and initialize devlp powder. could also do output check and turn toner motor on to make sure it works.
Apr 19, 2014 | Ricoh Aficio 3045, 3035 Kit
Either the feed motor in the back of the tube or inside the chuck where the opening of the tube sits, if you take the chuck appart there is plastic feed fins and they break off and don't feed the toner ( I would check the feed fins in the chuck first)
My alficio 1035 is having a paper jam on the drum area and immediately report error SC395 this problem started after a toner hooper change. the second problem is that it is losing toner and som is falling...
SC 395 Development output abnorma.
Remove the development unit and clean the gears.If necessary change the developer.Remove the OPC imaging unit and clean the cleaning blade.
Apr 10, 2013 | Ricoh Aficio 1035 Copier
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
RIcoh MP-4500
It's probably happening because the cleaning blade on the drum needs to be changed or replaced.
Oct 25, 2008 | Office Equipment & Supplies
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
97 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
