Question about NetGear RangeMax WPN824 Router
Someone has changed the password and I can't access the router
  • 83 Answers
Hey!
You can actually restore the router back to it's factory state.
-Router must be on.
-There's a small hole at the back of the router, and it says there "Reset." There is a button inside that will allow you to reset it to the factory settings.
-You can use a pin or a paperclip to reach the button.
-Press and hold it down for 10-15 seconds until the lights go steady then start flashing
-After doing it, your router is now restored to the factory settings
You can setup a new password for your router.
Click here for the PDF manual for your router.
Hope this helps! :D
Posted on Sep 09, 2010
Testimonial: "Thanks for the quick and simple answer to my query"
Wireless password
The wireless password for a router is established by the administrator of the router. This is whom you should ask for the password. Hacking into the router wont help you find it because the password is not displayed...it is a series of dots. You CAN, if you access the router setup, CHANGE the wireless password to something you can use - but if you are hoping to piggyback or hack onto someones service using their wireless password, you're out of luck.
Aug 10, 2014 | D-Link Computers & Internet
Need password on wireless guest account
The possibilities are -some one might have changed it for you. If someone got your password or hacked it then they could get on your network and change the password on the wireless router. Or did the router get reset without your knowledge(has the non-guest access changed)? If you left the default log in to the router you might want to change it also, it makes it harder even if someone gets wifi access.
Mar 31, 2014 | Computers & Internet
Guest access cisco connect
If you give your password out indiscriminately, someone could get into your router and change the configuration (password). Not sure if this pertains to your router. Try to configure the router again and close down guest access until you can get a handle on who you can trust.
Dec 19, 2013 | Computers & Internet
How to change wifi password on Buffallo AirStation WBR2-G54 router
I'm not 100% sure, but I think the password is actually programmed into the bios of the router, so you can't change it...could be wrong. If someone is using your router, they must be aware of your password, remove the password sticker off your router and keep it in a safe place
Nov 24, 2013 | Computers & Internet
Requiring password
If your wireless access suddenly requires a password, one of two things has happened...
either you are inadvertently trying to connect to a neighbor's wireless router, or someone has modified your router.
If you are certain it is your router you are attempting to connect to, and it is requiring a password you did not setup, your best bet is to perform a hard reset. There should be a reset button on the back of your router. You should press and hold this button for a few seconds. This will clear all setup information and return the router to factory setup.
In order to setup your router from this point, you will need to connect directly to the router, perform whatever setup options you prefer, and then you should be able to connect wirelessly.
It is highly recommended that you setup a password for wireless access. It is also recommended you change the admin password to prevent someone else from making unwanted modifications.
Jun 18, 2013 | NetGear N600 Wireless Dual Band Router
Some one keep changing my pass word i like this problem to stop Ty
Seems someone knows the IP address of your router, logs in and resets it and changes your password. Log into your router and change the IP address range like for instance if it's currently 192.168.0.100 change it to 192.168.88.100 or change the range to 195.168.1.100 and then they won't be able to log in any more but make sure you change the router's password as well because they may know it as well. Once this is done the only way to change your setup will be if someone had physical access to your router and held the reset button.
Sep 05, 2011 | Computers & Internet
Many people hacked my password so i want to deactive this id instantaly plz disable my account immediately
Try accessing the router's management console to change the password. If someone else changed it or you have no access to the router, press and hold down the reset button behind the router to reset the router. After you have reset the router, immediately change the password to prevent others from using it.
Mar 08, 2011 | Computers & Internet
Someone is acsessin my router and useing my internet without my permission i need to change the password but i cant
Reset both password (1) pasword for access router via GUI (2)Wi fi security password WEP or WPA or WAP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on administration and change password .
Then Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 17, 2010 | Belkin Computers & Internet
How do I make my router access secure?
look on the bottom of your router there is an ip adress, go to it and enter the password located on the same sticker the ip adress is on. Once you access this page you are in the router's setting, go to security and select the settings you want.
Mar 05, 2010 | Linksys Wireless-G WRT54G Router
I need to change my security password to my router. someone changed it so its not working
ok
access your router with following link
http://192.168.2.1
then type user name as "admin" and password as "admin" or "password" or blank
then go to wi fi security then go to encryption key and change it if you want to change then save setttings and check.
Jul 10, 2009 | Belkin (F5D7230-4) Router (587009)
NetGear RangeMax WPN824 Router Logo
430 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
