Question about Frigidaire FSC23F7D Side by Side Refrigerator
I can only get crushed Ice when the Cube Button is pushed. it seem the Cube Buton has failed. What can I do to solve this problem
  • 5,081 Answers
Pretty easy fix if you are somewhat handy with a screw driver. Remove the tray holding ice, on the side of that tray should be a metal rod that activates the crushed/cubed function. There is a motor on that activates a lever that will push the end of the rod down or pull it up depending on what you have selected.
Motor could have been frozen, since it is in the freezer, but you need to remove the mounting bracket and spiral rod assembly. To remove this there are two small bolts on the bottom of that bracket, remove those and lift up on the entire bracket assembly. This will remove from the mounting bracket at rear of freezer. Now for the hard part, you need to unplug the wire connection that runs into the back of the freezer. There are two plastic clips on each side of that connector. You need to push the top of those clips on both sides and pull the connector apart. All at the same time. The wire also is connected to the ice maker itself, so you also need to disconnect that connector, much easier to disconnect that, squeeze the clips on each side and pull apart.
Now you should be able to remove the entire ice tray and spiral gear assembly. Be careful as the light bulb is on the bottom back side and it is probably pretty hot as it has been on now for several minutes while you were trying to get all of this done. Now you need to take the back plastic cover off, by removing the two silver screws from the bottom rail. By removing the plastic cover you can gain access to the spiral gear motor and most importantly the cubed/crushed actuator motor. If it is anything like mine, it will be covered in ice crystals, let that melt or use a hair dryer to speed it up.
Once that is unfrozen, you should be able to move the metal rod (shaft) back and forth. There is a spring on the opposite end of the shaft from the motor and that will push or pull up the lever that in turn moves the rod to allow for cubes instead of crushed ice.
Once you have that shaft moving freely, reassemble the unit by replacing the rear cover with the two metal screws and place the assembly back in the freezer. Plug the harness back into the connector, it only fits on the female end one way, but you can look at the orientation of the round holes and square holes and get it lined up correctly. It goes together much easier than it came apart. The light bulb will turn back on once you have it connected correctly, don't forget to also connect pigtail connector to the ice maker itself. Now if you hold the door open/closed switch in and push the ice dispenser lever on front of door, you should see the motor push down the actuator that in turn will push down the end of the brass rod which then opens the latch at the dispenser end to allow cubed ice with out going through the crusher.
Make sure you have the cubed button on front activated before you test this. You will not see any difference by just pushing the cubed or crushed buttons on the front of freezer. You will only see a difference in that actuator once the ice dispenser lever is pushed. As long as that is working, make sure to replace the two metal bolts on the bottom of the mounting bracket. Replace the ice tray and enjoy your cubed ice. Hope this helps
Posted on Sep 09, 2010
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
My side b side fridgidaire will only make cube ice now not crushed
fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
Apr 10, 2015 | Frigidaire FRS3R5EMB Side by Side...
Why am I getting crushed ice when I requested cubes
Hello friend, thank you for your post!
I understand that you are receiving crushed ice even when you request cubed ice. It could be an issue within your control panel or solenoid. Since it could be any one of these under lying issues I would recommend having a technician come out to properly diagnose your appliance. Hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
WHEN I PUSH BUTTON FOR THE CRUSHED ICE IN THE DOOR I GET CRUSHED ICE BUT WHEN I SWITCH THE BUTTON TO CUBED ICE NO ICE COMES OUT BUT THE BUTTON LIGHTS UP WHEN SWITCHING FROM CRUSHED TO CUBE EVERYTHING ELSE...
You will need to check inside the ice tray for anything that may have fallen in. Sometimes the ice itself with stick into clusters and will not dispense. I would take out the tray, empty it, rinse it and re install it. Good luck!
Sep 15, 2011 | Whirlpool Refrigerators
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice crusher stuck on crush mode can't swith back to cube
is it push button or do you manually have to turn dial from crush to cube. I have push button and had this problem once before.(LG side by side) I turned off at power (remove cord from wall) and removed ice tray all together. save some ice for testing. Check to see if crush part was clean. Put ice back in container and put back together and turn back on at power point. See if you can have cubed now.
Dec 14, 2009 | Frigidaire FRS3R4EW 33" 22.6 Cu. Ft....
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
Jul 06, 2009 | Frigidaire FRS23H7CS Side by Side...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
110 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
