Question about Whirlpool Refrigerators
Hi my refrigerator whirlpool Imperial series, model ED5JHAXML00 is not cooling and is not making ice. How I can know what the problem is and which part should I replace. Thanks.
  • Mike Smith
    Mike Smith Sep 09, 2010
    Need a little more info . Is there frost on the back wall inside the freezer ? Do you feel the compressor running ? Is the compressor hot and not running ? Do you hear a " click " occasionally ?
  • Anonymous Mar 28, 2014
    Whirlpool Imperial Series side-by-side refridgerator model ED5JHAXML00 In-Door Ice Con...
  • 5,081 Answers
Do you hear and compressor running sound when you turn it ON?
Posted on Sep 09, 2010
Hello I have a whirlpool side by side model # ed5jhaxml00. The ice maker stopped working, I still have water in the door. I replaced filter and is still not working. Any Ideas?
American Appliance
Hard to know exactly without being there on the spot but the link will provide good information on how they work. Your fridge also has a dual water inlet valve. The door can provide you water while the ice maker can not receive water because of the second inlet valve.
Whirlpool W10408179 Water Inlet Valve AppliancePartsPros com
Jan 15, 2015 | Whirlpool Refrigerators
Why is my 2001 Whirlpool Imperial Series side by side refrigerator frosting up around the ice maker?
Ice makers can do this for several reasons. One is the incoming temp of the water is causing condensation to form and it freezes. Another reason is air leaks from the ice maker door.
Aug 22, 2014 | Refrigerators
My ice maker stopped making ice.We have the Whirlpool Imperial Series with the water and ice in the door. The water dispenser is working fine.
The heater has a timer, and a temperature sensor. It senses when the water has turned to ice the temperature has reached certain degree. If the sensor or the timer malfunction then you would end up with the heater coming on too soon and the ice would not have time to freeze.
Nov 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool Imperial Series refrigerator that has water coming from the bottom- onto the floor. The evaporation pan is nowhere near full. It is not apparent where the water is coming from. Any...
Hi, Dounfd like the defrost drain in the freezer is plugged. Remove the rear panel inside the freezer and locate the drain hole under the evaporator coil.
Once all the ice has been removed, flush the drain with hot water. Some models require an after market drain heater kit. If you will get me a model #, Ican look this up for you.
Vic
Jul 02, 2009 | Refrigerators
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool imperial series freezer not cold
my freezer is not getting cold enough but it still makes ice
Feb 08, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
Whirpool Imperial Series UltraEase II side by side refrigerator is leaking from underneath the left side.
hi. thanks for the question .pull fridge away from the wall. remove back panel, clean all coils. look for leak. the tray is suppose to evaporate, from the heat from coils ,and compressor .so it has to evaporate .thanks the appliance doc
Aug 17, 2008 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
338 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
