Question about Mitsubishi WS-55511 55" Rear Projection Television
My 55 inch Mitsubishi is 8 years old. when I turn it on the picture is distortedand blury. After about 20 minutes the problem goes away. Can this issue be fixed aon a set of this age or should it be replaced?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
IT MAY BE A CONVERGENCE PROBLEM, see some photos and let me know if anything like your problem.
If convergence you will see it better by going into the menu and selecting first convergence, then advanced---this will bring up a grid of lines--should be yellow with no red or blue out of place.
Good news: if this problem it can be a do it yourself repair--I have start to finish, step by step instructions for this repair in this set.
Let me know what you find and I will assist you.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 09, 2010
The picture is stuck in pip cant get it to go away
Turn it off manually (unplug the power cable), it should reset itself after several minutes (10-20).
Dec 08, 2011 | Mitsubishi WS-55513 55" Rear Projection...
Green light flashes under timer when tv is turned on. no picture
Sounds to me that the DM is the cause. If this model is 7-8 years old, it uses a DM that is no longer available or supported by Mitsubishi. You could confirm this by calling Mitsubishi at 1800-332-2119. This is there Customer Service Line.
Hope this helps,
Skyassoc
Jul 18, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
Jun 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
May 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after...
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Oct 20, 2008 | Televison & Video
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws- 55807 clicking sound
My tv was working fine until now 8-9-08, it would not come on. The timer light comes on and goes off immediately.
Jul 20, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
