Question about Roper Refrigerators
Frezzer working but frig not staying cold. replaced thermostat but did not work. so what now?
    President:
  • 3,773 Answers
Go here to one of my tips.
You might be surprised.
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need Parts go Here
1-877-779-5418
Posted on Sep 09, 2010
  • Roper Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Frig quit working.....unplugged....plug back in and it works for.about 3-4 days then quits working again....did this 4-5 times in a month with the same results. I have replaced the thermostat in the...
have u checke the defrost heaters in the frezzer. also the termnation switch with the heaters.. if they dont work then it dont defrost and it builds up ice and wont work properly. ok
Feb 16, 2011 | Refrigerators
My samsung side by side was working great untill
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
Hi we have a GBS22HCPABB fridge and the motor runs, frezzer works but fridge will not get cold just stopped
you have a few possibilities 1. a defrost problem restricting air flow from freezer to ref. 2. a bad freezer fan motor 3. a damper issue not opening to allow air to flow from freezer to frig. most all refrigerators generate the cooling from the freezer to the frig via the freezer fan motor
Mar 06, 2010 | Refrigerators
Our frig will frost up on the frezzer side and the refigerator side will not stay cold what can cause this?
you have a defrost problem,you could have a bad thermostat,a bad timer or addaptive defrost board,you didn't send model number so i can't tell you what you have there or a bad heater,you need to take off the back wall inside the freezer,and read out the heater and thermostat to see what's bad,and melt out all the ice,if you want to send model number i can look it up for you,also when you open the freezer door do you hear the fan blowing,if not you could have a bad evap fan motor
Jan 27, 2010 | Kenmore Refrigerators
Fridge not staying cold
First make sure that ur frig.is level. Then checx the cooling coils in the back. Make sure that all the vents,frig. and frezzer, are clear. Ur moisture control could be another factor.
Sep 13, 2009 | Refrigerators
FRIDGE STAYING AROUND 25 DEGREES
you have a gas leak , a refrigeration mechanic is required.
May 10, 2009 | Admiral 26 cu. ft. Side-By-Side...
Frezzer to cold and Frig is cold a little
Dear customer,
                     It maybe the makfunction of defrost timer howevet we recommend you to do the following before checking the defrost.
  1. Check the temperature setting
  2. Test the  temperature control
Click on the highlighted words to know how to test them.  If they seem to work fine then check defrost timer using the reference link  http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosttimer.php
Thank you..
May 07, 2009 | Refrigerators
Refrigerator not cool
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 19, 2008 | KitchenAid Refrigerators
Freezer works but frig is not cooling
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
242 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
