Question about LG Computers & Internet
When monitor is turned on, the words 'Check signal cable' appear. What does this mean? Thank You
  • 83 Answers
Hey!
If you get that message on your screen. It is possible that there is no communication from the tower to the monitor.
Please make sure that the cable that is connected from the monitor to back of the tower is properly connected.
Also check if the lights on the tower are on and try to check if they're the ones that you normally see when you use your computer. It could also be possible that the computer is encountering a problem.
Hope this helps! :D
Posted on Sep 09, 2010
Power went off no monitor is giving check cable error
If you're seeing a "Check Cable" message on the monitor - it's working. If this message appears, it means the monitor isn't receiving a signal from the computer. Cable could be loose, or video circuit has failed.
Nov 19, 2014 | Computers & Internet
Acer x193w Monitor won't come on flashes blue light you see word "Acer" it goes to flashing Yellow light and keeps repeating that.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Oct 13, 2011 | Acer X193W LCD Monitor
I have a e machines desktop that will not boot up. I turn it on and the monitor says no signal. I think it might be stuck in hibernation mode. The fans on the tower start but thats about it. If some one...
No Signal means you Display or Monitor is not getting signal from Video Card.
In this case:
1. Check if all the cable are properly plugged in. Check on both monitor and computer back. 2. Check if cable is not broken. 3. Try unplugging cables and plug them back. 4. Try some other monitor or cable. 5. If cables are fine than problem could be with your video card.
As you are getting No Signal that mean your monitor is working fine. Problem is either with cable or video card.
Jul 06, 2011 | Computers & Internet
Ok when i turn on my aoc monitor colors like blue green red white pop up i can never use my desktop
I would suggest that you try another monitor. If the monitor continues to light up with these colors and you do not see your computer desktop, then I would tend to think that your computer may have a problem with the video card or driver. Do you get a message on your montor with words like "no connection" or "No signal". If so, this means that the monitor is getting no video signal from you desktop. Try disconnecting your monitor plug and removing power from the monitor in an attempt to reset the monitor. Try also to turn off and unplug your computer. Leave the computer unplugged for about 10 minutes and start it up again. This may reset your computer. If you monitor video cable will disconnect from the monitor, you may want to get a new cable. These cable do go bad sometimes and are available and inexpensive on Ebay.com
Try these ideas and let me know how you do.
If you found this answer helpful, please remember to leave positive feedback. If you need more assistance, let me know.
Thank You,
Brian
Mar 20, 2011 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I have a samsung 17'' lcd monitor.when i power on my monitor without data cable i got a message on screen CHECK SIGNAL CABLE.when i connect data cable my lcd is going to power off.please help?
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Oct 03, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
When i turn my monitor on it goes on and shows the acer logo then says no signal and just goes off and this just happened one day i have never had any other problems with it before
If you monitor shows no signal that means it is not connected to the computer properly and not getting any video signals from the computer. You need to check the vga cable properly Try removing the cable from both ends and and reseat the cable. Try another VGA cable. If you are using a Graphic card make sure the card is connected properly
Please feel free to get back for any further assistance.
Thank you for choosing Fixya
Jan 25, 2010 | Computers & Internet
Monitor comes up shows "acer" then says no signal and goes black
This Problem is Acer(s) Monitors. Though it is a nuisance one fix That has work for many is the Unplugging after it goes back to Good (viewable) screen.
I have hooked mine up to an inexpensive Power strip to make it easier for me and just turn off at time indicated above and Viola Simple is as Simple does :)
Apr 24, 2009 | Acer X241Wsd Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
Samsung color monitor
This problem may arise from monitor as well as from cpu.
First of all check it by unplugging the VGA monitor cable.
This will display the "Check Signal Cable" depending on the model of the monitor. But a message will appear rolling on the screen, if it is not a very old monitor.
If the message is appearing OK and green light is continuously on, that means ur monitor is working fine.
The problem may be with VGA cable or with the booting of CPU and probably the RAM. Recommended solution is to reconnect the RAM and then try, if u think u can do. Otherwise call a hardware engineer.
If there is no message and still the light is turning green and yellow. That means the problem is definintely in the monitor.
Thankyou,
Your well wisher
Nov 27, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
54 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
