Question about Texas Instruments TI-83 Plus Calculator
TI-83 plus does not turn on. Replaced AAA batteries and also checked back-up battery It is OK
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please append a comment to this post and we'll go on from there.
Posted on Sep 09, 2010
  • 1 more comment
  • jerrygallowa Sep 10, 2010
    Just got a TI-83 from my daughter, changed batteries and appeared not to come on. Tried above solution but still does not appear to come on. Any other suggestions ?
    Thanks
  • jamenn Sep 15, 2010
    Tried everything . . . still does not work :(
  • rellz0927 Sep 19, 2010
    Tried the above solution, still doesn't work. Any other suggestions?
  • 44 Answers
If you are not using Alkaline batteries, try that, some devices like that wont run right with regular batteries.
Posted on Sep 10, 2010
  • kakima Sep 10, 2010
    Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Does the calculator come on now (you may have to adjust the contrast as described earlier).
I get black "lines" going across the screen when i hit the graph button. It will graph also,but you can barely see the graph. Help pleae.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
I have a TI-83 Plus. It just died. I have replaced the 4 AAA batteries and the lithium 1616 backup battery. I have checked to verify that the screen hasn't just dimmed. I get nothing. Any ideas?
Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Turn the calculator on (you may have to adjust the screen contrast again).
If this doesn't do it, please add a comment to this post and we'll go on from there.
Sep 10, 2010 | Texas Instruments TI-83 Plus Calculator
Entire battery replace but still wont turn on
Feb 22, 2010 | Texas Instruments TI-83 Plus Calculator
Texas instruments TI-83 Plus won't turn on. I have replaced the AAA batteries.
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at ti-cares@ti.com or www.ti.com/calc.
Nov 09, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
Dark screen, no blinking cursor
press 2nd and the down button (hold down button)
Jan 14, 2009 | Texas Instruments TI-83 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus Silver Edition problem
These instructions are from education.ti.org, and worked for me.
1) Take out one of the AAA batteries
2) Hold down the CLEAR button
3) Put the AAA battery back in while still holding down the CLEAR button
4) Let go of the CLEAR button and turn the calculator ON
5) Press CLEAR to get rid of the error message.
Then you should be good! All the applications on my calculator were still intact, so despite the error message, the RAM was never actually cleared.
Oct 20, 2008 | Texas Instruments TI-83 Plus Calculator
Ti 83
Remove one of the AAA batteries. Press and hold CLEAR while reinstalling the AAA battery. Continue holding CLEAR button and press ON. Release buttons and press CLEAR again.
Jan 02, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
217 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
