Question about Linksys Wireless-G Broadband Router
I lost power, when this has happened in the past I just unplug and replug the router and it fires up with no problem, but this time it does not, the only light I have on the router is the power light and diag light. Did I fry the router?
  • 6,831 Answers
Hello
Yes, this is most probably the case. If you are very lucky you might have only damaged the firmware, but, it is a long shot. Have a look if a firmware upgrade does the trick, otherwise, sorry man.
Let me know if you found this helpful.
Kind regards
Andrea
Posted on Sep 09, 2010
Wireless router will not power up?
Capacitors in the power supply have gone bad. Might be time for a new router.
Mar 06, 2016 | Belkin Connect N150 Wireless N Router
Can't get online
Try power cycling the router:
1. unplug the power cord from the router
2. unplug the power cord from the modem
3. replug the power cord to the modem
4. replug the power cord to the router
for best results, wait approx. 30 seconds before re powering the devices.
Mar 03, 2011 | Computers & Internet
I cannot connect to my wireless network.
Try choosing the option "Repair" in your task bar. If that doesn't work, most of the time simply unplugging and replugging in your router from the power supply will do the trick.
Mar 01, 2011 | Linksys Wireless-G WRT54G Router
I lost power and when I unplugged and replugged the router, the only light that come on are the power and diag light
Hi!
You need to folloow the steps below if Diag Led lights keeps on flashing overtime:
Click start then access control panel Go to Local area connection - properties - internet protocol/TCP-IP then use the IP Address: 192.168.1.50 and Subnet Mask:
255.255.255.0. after these download the most recent firmware version for your router that can be downloaded from your router's manufacturer website. Restart your devices after firmware version upgrade.
Should you have any other questions just please leave a message.
Cheers~
Sep 09, 2010 | Linksys Wireless-G Broadband Router
My playstation has been working fine for the past 6 months and now suddenly wont let me sign in online it says it timed out trying to find the ip adress. i tried going online with my brothers one and it...
Oh Wireless card is failing, or your Internet Router doesn like you.
Reset the router by unplugging the power for 10 seconds then replug that back in, and try again
Apr 07, 2010 | Sony PlayStation® 3 (80GB) Console
Wireless connectivity suddenly lost
Have you tried power cycling the router and the modem? if not:
1. Turn off your modem and router by unplugging the power cord at the back of the devices.
2. Disconnect the Ethernet cable from the modem to the router vice versa
3. After a minute, replug the power cord at the back of your modem then reconnect the ethernet cable at the back of the modem as well.
4. After a minute, replug the power cord and the ethernet cable at the back of your router.
5. Try to test the connection.
Warning: You can reset the router if you know that you can reconfigure it back to connect to the internet. If you don't know how to set the router back to connect to the internet, it would be ok to you to not to do step 6.
6. If it didn't work, You can reset the modem. Press the reset button at the back of your router while it's turned on, wait for 15 seconds after that, unplug the power cord at the back of the router while the reset button is still pressed, wait for 15 seconds after that, replug the power cord at the back of your router while the reset button is still pressed, wait for 15 seconds again then release the reset button after 15 seconds.
7. Reconfigure your router's settings to communicate to your modem. ( I don't know if you have cable internet connection, but if so, you can just clone the mac address of your modem to connect to the server, if you are using DSL if it's asking for a username and passowrd, just use the PPPoE type of configuration in your router)
8. If it failed, try to update the firmware of your router.
Jan 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Power light blinking not working cannot re set
Was there any power flicker before it happened?
1. Reset the router by pressing the reset button of the router for 15 seconds while the power cord is plugged in and while the router is powered on.
2. Release Reset button after 15 seconds and unplug the power cord of the router then press the reset button again for 15 seconds.
3. After 15 seconds release the reset button and replug the power cord then press the reset button again for 15 seconds.
If this didn't work.
1. Plug the power cord to the router, and unplug it do this 7 times then reset for 15 seconds while it's unplugged and plug it back it and press the reset button for 15 seconds and release it. Try to check if there's any changes.
Jan 09, 2010 | Linksys Wireless-N WRT150N Router
My belkins wireless light wont come on anymore?
* try connecting ur belkin router to different power socket * try with different power adapter * or else press the reset key for more than 1 min while holding the reset unplug the router power cable and plug it back again 3 times.--- while holding the reset u shouldnt release the reset while u unplug and replug. the interval between each unplug and replug should be 15 seconds. * then release the reset then unplug the power cable and plug it back * it has to work or else replace it with the belkin tech support
Nov 15, 2009 | Belkin (F5D72304F5D7000) Router
Emachines t5060
Reboot your computer,
Check your cables in machine especially the one that looks like an oversized phone cord. (cat5). Unplug replug.
If you have cable modem power down along with any wireless router power cable modem up first wait 30 seconds to 1 minutes. Then power router on
If it is dsl just unplug and replug the dsl modem and any attached routers plug in dsl modem first then plug in router if applicable.
If your at work try
Dec 26, 2008 | E-Machines eMachines Desktop PC
Lost my connection to wire less router , the phones were down last week and after that we have to plug into router
powercycle your homenetwork. this step works 90% of the time. to powercycle your homenetwork, shut pc down, unlpug the power cable from the router, then unplug the power cable from the modem. give atleast 10 -15 seconds for your devices to refresh the connection. then in turning them back on, replug the power cable for the modem first, with for the sync light be turn solid, replug power cable for the router, then turn pc on.. try pulling up websites, you should be online now. just in case you still can't, bypass the router and connect the modem straight to the pc first. try connecting online, if you can't configure the modem to go online, once done, connect the router back to the equation and reconfigure its settings. you the should be up and running. i can help more if you'll tell me what's the modem and the router..
Dec 13, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G Broadband Router Logo
104 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
