Question about Toshiba TN55X81 55" Rear Projection Television
Red color is off alignment. Picture is blur. how to re-align color on TV?
  • 505 Answers
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Posted on Sep 09, 2010
How do i set convergence of red,green ,blue through service mode
Most common cause for this on the Sony KDL 40EX520 is that the connections to the screen across the top edge of the panel become loose causing blurred picture, mis-aligned colors etc. The Fix requires dis-assembly (Removal of the entire case) and re-seating/resecuring the connection across the top of the LCD Panel.
There is a pretty detailed video of the process (less the disassembly) here: https://www.youtube.com/watch?v=80PfZXFGDvQ
Jan 10, 2015 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Picture quality
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 06, 2010 | Philips 55PP9401 55" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Alghin red green abd blur colors
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Apr 21, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Red color does not align
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Televison & Video
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
Color appears out of alignment. The set has
Replace the STK392-110 Convergence ICs and the 6 1.8 ohm 1watt resistors. You can get the repair kit whcih also contains the instructions from www.tvrepairworld.com
Nov 24, 2009 | Toshiba 50H82 50" Rear Projection...
The color plates aren't aligned anymore.
YES BUT A QUALIFIED TV REPAIRMAN SHOULD DO IT
Jul 21, 2008 | Orion STV2763 27" TV
IM HAVING A SLIGHT PROBLEM
You need service. Sounds like the convergence is out of adjustment. As the picture is formed by a tri- gun arrangement (one for each colour), if any of them is not correctly aligned, you will see shadows on any sharp line like text, or blurring on a picture. The shadow or blurring will often be one colour i e. red, blue or green.
Mar 27, 2008 | Mitsubishi VS-45609 TV
Toshiba TN55X81 55" Rear Projection Television Logo
271 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
