Question about Dewalt 18 Volt Xrp Heavy Duty Hammer Drill Kit
Put drill in revcerse and the chuck comes loose dropping the bit out
  • 490 Answers
Yup, that is what happens. You can lessen that by really cranking it down, but it is an issue with most hand tightened chucks, and does not indicate a mechanical failure. I sometimes miss my old, heavy Milwaukee wrist-breaker with the keyed chuck. If it is just too much to live with, you could get a drill with the click in hex chuck or put a Jacobs keyed chuck on your hammer drill.
Anyway, I hear where you are coming from and share your frustration.
Regards, Farmerbear
Posted on Sep 09, 2010
Why does my chuck keep loosening
First check whether you have the correct transmission setting for the bit you are using. This may affect the range over which the chuck operates and how it locks onto the bit. A conventional small-diameter drill bit may not work with a hammer drill setting. If the setting is correct, then either your hands aren't as strong as they used to be and you're not getting the chuck tight, or the chuck is worn and no longer has enough friction to hold.
Try this diagnostic: when you put a bit in, use a fine-tip felt marker to draw a line from the chuck collar (the part you turn to tighten or loosen) to the chuck baseplate. If the bit comes loose, check to see if the collar is still lined up at the same place relative to the baseplate. If it is, the chuck pieces are slipping inside; perhaps the transmission setting is incorrect for the bit chosen. If the collar has worked loose (the marks didn't stay lined up), the threading on the collar or the parts it engages could be worn.
May 23, 2014 | Dewalt 18v Battery Hammer Drill Dcd950...
I having problem of drill bit would like to know how to remove drill bit
Make sure the chuck is loose then clamp the drill bit in the vice and give the drill a straight pull ,once its out then put some engine oil down the chuck and let it soak in ,not that fish oil spray stuff .
Dec 02, 2011 | Metabo 600661620 SBE660 12" 01000 03000...
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
How do I change a bit
This drill uses a keyless chuck. which means you have to hold onto the barrel by the end of the drill chuck. Then you need to put the drill in reverse to open the chuck to put a bit in. Insert a bit and then put the drill back into forward and hold chuck to tighten.
Nov 14, 2010 | Milwaukee Tool Milwaukee 0824 24 v18...
I can't get the drill bit out of My Makita 6333D cordless hand drill. I usually have no problem. I did tighten the chuck pretty tight, but now can't loosen it. Help.
put the drill in a vise and using a pair of channel lock pliers grip the chuck and it should come loose will a little tug on the pliers
Sep 12, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Drill bit keeps coming loose
When the drill bit on a hammer drill keeps loosening up one of two things is happening. 1. The chuck is worn out and needs to be replaced. 2. The chuck is not tight enough before you start drilling. If you have the style of chuck that requires a key do not be bashful about using maximum force to tighten the chuck and move the chuck key from hole to hole and tighten it in each position. Joe
May 08, 2010 | Drills
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
My rattle gun 18V LXT Impact Driver BTD141 has a double ended Philips stuck in it? how do i get it out?
There are a couple of ways to try to free the bit from the drill chuck. But slow and steady is the key, don't hit anything too hard, so as to not damage the chuck in the process, nor break off the bit in the chuck.
You'll need to put the bit into a bench vise and reverse the drill slowly and carefully. Make sure the bit is tightly secured in the vise and that the drill won't spin your hand around and slam it into the bench when you pull the trigger.
As a last resort, you can try tapping the bit sideways, to get it loose. With chuck opened up all the way possible, gently tap the bit sideways. This should also free the bit, but be very careful not to snap the bit off in the chuck, or you'll have a worse situation trying to get a broken bit out of the chuck.
If none of these work, you can attempt to secure the stuck bit in the bench vise and try to tap the drill chuck using a hammer and a flat brass bar resting against the drill chuck, so you don't damage the chuck. Just tap the brass bar to drive the chuck free of the stuck bit. You have to watch the bit in the vise to make certain it's not slipping and that the chuck is getting free.
Hope you find this Very Helful and best regards!
Jul 12, 2009 | Drills
Keyless chuck will not tighten down enough to hold bit
What size bit are you using if it is real small it may be below the min sixe require for that chuck .If it is say 1/8 or larger it may be time for a new chuck .They are easy to replace open the chuck as far as you can there is a screw inside them most of them are left hand threads just back it out and tap the chuck loose with a hammer .Make sure you know the threads of your chuck when you buy the new one most are 1/2-20 but some can be 3/8-24 tpi
Nov 18, 2008 | Black & Decker HPD18K - 2 High Performance...
Dewalt 18 Volt Xrp Heavy Duty Hammer Drill Kit Logo
165 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
