Question about PfaFF Creative 7570
My pfaff 2170 says "main motor blocked" how can I fix this?
It happened to me... Check the bobbin and thread in the shaft ... Pull out the bobbin and remove all thread from the shaft. Pull out any thread remains with the tweezers. Check the feeder dogs and the needle (see Owner's Manual 2:7). Re-insert the bobbin (see Owner's Manual 2:12).Make sure that you use a good quality thread and set everything up correctly. Good luck!
Posted on Oct 22, 2010
Pfaff 2170 main motor blocked;Tried again, same message. It works fine for five or 10 minutes, then stops and message comes up. after overnight rest, same thing happens. tension, cleaning is fine.
Take it back where it was serviced and tell them they did not fix the problem. They should either repair it or give you your money back. If the motor is having issues, there could be something seriously wrong.
Mar 19, 2017 | PfaFF Sewing Machines
I have a 3D/ Pfaff 2170 Creative & I'm using Windows XP. No device found error. I can not transfer the embroidery design to 2170 Pfaff. Help!
Sounds like you don't have the device driver on you computer for the sewing machine. Question: Did it ever work? If it used to work but doesn't now, try using a different cable from the computer to the sewing machine. You can also try rebooting the computer (with the sewing machine connected and powered up) to see if it will locate the machine.
Dec 19, 2014 | PfaFF Sewing Machines
Bobbin shuttle is loose cant tighten on pfaff 2170
I wouldn't play with the shuttle.....take it in for service. You may make it worse by trying to fix it yourself.
Feb 04, 2014 | PfaFF Creative 7570
My Pfaff 2140 giving message main motor blocked.
I have gotten the main motor blocked message several times. When I get this, I always remove thread, both top and bottom. I change the needle too. 75% of the time my problem goes away. If the problem is not solved, I unscrew the casing in the front of the bobbin, and look for anything that might be obstructing the bobbin. While I've had lots of "blocked motor" messages, I've never had to get a tech to ook at it. Sometimes, if you leave it overnight too, the sewing machine fairy will change something and the problem will solve itself in the morning. Re-thread, re-bobbin, re-needle. to start.
Dec 22, 2008 | PfaFF Creative 7570
Pfaff 2170 Query
my pfaff 2170 machines shows "Cannot make Directory" pls help me in this
Apr 26, 2008 | Sewing Machines
Sewing Machines Logo
671 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
