Question about Intel Gigabyte GA-8S661FXM-775 SiS 661FX chipset 800MHz FSB DDR 400 Socket 775 mATX Motherboard with AGP 8... (MB77GB661FXM)
Bios won't boot, fans work, drives are flashing but it won't boot, no beeps.
  • Intel Master
  • 27,725 Answers
Try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 09, 2010
5 Suggested Answers
map9966
  • 2351 Answers
SOURCE: wont boot into bios
Hi anp62, you can contact MSI & order a new bios chip. Most manufacture's charge about $5.00 US.
It is worth it before trashing the board. You can contact MSI at the link below. http://www.msicomputer.com/support/OnlineTS.asp
Check MSI's Basic Troubleshooting Guide, so I don;t have to type all these checks.
Click here: http://www.msicomputer.com/support/sup_tshoot.asp
Mike
Posted on Sep 26, 2008
nicoleFIXIT
  • 154 Answers
SOURCE: It will not boot up, fans spin, no video and 3-4 beeps
If you have encounter this kind of trouble this is a RAM problem which is beeping. B
Beep code pattern on a PhoenixBIOS system means that there has been an issue while testing the DRAM refresh. This could be a problem with the system memory, an expansion card, or the motherboard.
Random Access Memory (RAM) is the "working memory" in a computer. Additional RAM allows a computer to work with more information at the same time which can have a dramatic effect on total system performance.
RAM is typically referred to simply as "memory" even though other types of memory may exist inside a computer.
At this time you need to check the memory. Remove the memory and turn it on identify in there is sound provided.
Memory is installed in the memory module slots located in the motherboard. These slots are easily locatable by looking for the small hinges on either side that lock the memory in place. Certain sizes of modules may need to be installed in certain slots so always check with your motherboard manufacturer before purchase or installation.
Posted on Oct 07, 2009
  • 644 Answers
SOURCE: Packard Bell IMedia 5055: GA-8SIML will not post
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Posted on Feb 04, 2010
swufabuda
  • 219 Answers
SOURCE: hi guys, I have a computer with Gigabyte
Sounds like your on board graphics are bad, but since you have a pci-e expansion slot you can buy a pci-e graphics card to get it going. Hope this helps..
Posted on Aug 06, 2010
Alarm beeps and orange light flashes when power is switched on.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Feb 15, 2014 | HP Pavilion Computers & Internet
BIOS Update was interrupted. Now laptop won't boot up.
basically your screwed , if the laptop is still under warranty I would return it without telling them u tried to flash the bios....ergo if they find out you will not be covered for warranty
the only other thing you may be able to try is inside of the laptop casing should be a small round battery usually wrapped in heatshrink or alike if you unplug that then unplug power source (main battery) and hold power button down for about 30 sec then replce both batteries and turn on it may reset bios to factory but is highly unlikely!!! you may need to contact the creator of the nios system!!!
Jan 25, 2013 | Intel Lenovo ThinkPad T410 2518F4U 141in...
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
I try update my bio on my ao0751h netbook acer, and doesn't successfully, now my netbook doesn't turn on. How i recovery a bios?
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive.If you have a PCI video card,you won't see anything on the screen because the boot-block BIOs only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
  1. Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufactures send them for free.
  2. Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or Bios World
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
  1. Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
  2. After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
  3. Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
  4. Flash an appropriate BIOS to the corrupt BIOS and reboot.
Solution 4: (for Intel motherboards)
  1. Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
  2. Install the bootable upgrade diskette into drive A:
  3. Reboot the system
  4. Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
  5. Turn the system off
  6. Change the Flash Recovery jumper back to the default position
  7. Leave the upgrade floppy in drive A: and turn the system on
  8. Continue with the original upgrade
Feb 03, 2010 | Computers & Internet
Emachines notebook m5310 corrupted bios recovery
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive. If you have a PCI video card you won't see anything on the screen because the boot-block BIOS only supports an ISA videocard.
Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufacturers send them for free.
Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or BiosWorld
Note: Use a flasher from MRBIOS. They are known to work best. You can find them at ftp://ftp.mrbios.com
Reboot the system
Turn the system off
Oct 14, 2009 | Computers & Internet
IBM T20 hard disk won't start, no display, and beeping
it may be drive issue,:
- replace the hd and cmos battery,
- change boot device priority in BIOS
to 1st: cd/dvd
2nd: hd
3rd: floppy or network boot or usb-boot
- exit BIOS saving changes: yes
- reboot from windows cd-rom for testing the cd drive
- try booting from new hd (if bios recognizes it,
then install operation system
- if still the same prob, see a technician about this issue
Jun 13, 2009 | IBM ThinkPad T20 Notebook
Computers & Internet Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
