Question about Reliance Water Heaters
Leaking water out of the top of the unit - Reliance Water Heaters
  • Reliance Master
  • 43,501 Answers
The news is only bad... you have a leak in that hot water heater and it will need to be replaced... there is no way to fix them...
heatman101
Posted on Sep 09, 2010
Water is seaping around the top but it is not coming from the main gasket .
Discovering the source of the water leak can be difficult ,but water leaks commonly occur near the roof sheathing.
Jan 04, 2018 | Amtrol Water Heaters
My hot water tank is continually leaking ? I shut off the valve at the top of the tank and it is still leaking ??
They wear out especially if they are older. You did not say what make and model it is but if there is water coming out the bottom it is time for a new unit. The leak is still happening because even though there is not supply pressure, gravity is pulling the water out the break in the liner.
Jul 05, 2016 | Water Water Heaters
I have a Reliance 501 40 gallon water heater leaking warm water from the valve at the top of the unit. Steady leak. What should we do short term, and is there a part we can get to fix it?
i am not sure if you are talking about a shut off valve or the pressure relief valve. the relief valve should have a pipe from it going down the side of the water heater. if that is the leak the it can be replaced. there should be a little lever on top of it and some times by lifting it and letting a little water flow through, it will stop leaking.
Oct 19, 2010 | Reliance & 50gal Electric Water Heater
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Lower element leaks between brass and plastic power board
You need to check for a leak from one of the supply lines, if they aren't leaking, then the unit has developed from the tank. If that is the cause, you will have to replace the water heater.
Apr 11, 2009 | Water Heaters
61 Gallon Rheem Water Heater is leaking!
TANK COULD BE LEAKING BUT NOT USUALLY @ TOP CK ALL FITTINGS VERY CAREFULLY AND BE SURE IT IS NOT ONE OF THEM
Feb 21, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Reliance gas water heater 40 capicity, has a leak on the top
Most likely only one of the pipes is leaking but weaping enough to cover the top and indented places near both inlet and outlet. This leak has most likely penetrated all the insulation and is a problem throughout the tank wrap insulation...If you are able to blow air continuously long enough to determine which connection is leaking then fix it. It will likely to take quite a while to dry out all the insulation if the water has migrated down into the tank wrap... If you determine that the insulation is waterlogged, you may be able to drill several small holes in the external cover.
good luck
Jan 03, 2009 | Reliance Water Heaters
Water Heaters Logo
251 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
