Question about Dryers
Hotpoint ultima logic sensing condencer TDC62 is not drying clothes, it doesn't appear to be heating up
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 09, 2010
Hotpoint TDC62 drying clothes ok but not cooling down at end of cycle
I would check the cycling thermostat, the hi limit, the moister sensor, control board lastly
Mar 21, 2015 | Hotpoint Dryers
Hotpoint Ultima Condenser Dryer TDC62 - No Heat
That trouble is cause by an heater that is already open- no connectivity. Also the wire connected to it.
I hope I answer your problem.
Mar 23, 2011 | Hotpoint Dryers
Hotpoint TDC62 condenser dryer does not heat up Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why? If you tap the machine the...
Most likely, the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Your thermostats and heating elements are good (don't change these).
Jan 17, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint condencer dryer TDC62
Several reasons for it not to heat.
Obviously faulty heater, and or thermostat(s). You need meter to test. Heater and stats are located at the rear of the m/c behind a removable panel.
Faulty programmer, faulty heater relay.
Check filters etc, refer to instructions for this.
Plz leave feed back on this .
Thanks.
Dec 12, 2008 | Dryers
No heat
First thing to check are cutouts located above element. Should have continuity on both. take care element is fragile. Some models have a third located in the door space although this one is rarely prone to fault.
Nov 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Utima Logic Sensing Condenser TDC62
lewensc...this sounds like a classic timer issue. Before replacing it, first turn off your mains breakers and then back on. Check all wiring from the breaker panel to the unit. If okay, then have a quick look at the items in the dryer and test them using a multi tester. If nothing is amiss, replace the timer.
Dec 17, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
391 people viewed this question
Top Dryers Experts
