Question about Fisher and Paykel (IWL12)
I have just owned a Fisher & Paykel washing machine GW 712 7.5kg for less than a year and now its not working apart from 3 lights flashing on and off and a beeping sound
  • 343 Answers
F&P washing machines have a self diagnosis capability. However you have to be able to programme the fault mode and be able to interpret the binery display.
It would be best if you called a tech, because ,although the fault could be a simple one, there is always the chance that a component has failed and caused another to fail as well. (Not uncommon with F&P machines)
If you replace a part it might fail again because of a secondary fault.
An experienced tech will check the machine completely, and replace the part or parts and should warranty the work and parts.
You won't be covered by a warranty if you install the parts yourself..
Probably not what you wanted to hear, but a lot less heartache and stress in the long run...
TIP.. Get quotes for fees, experience and warranty before you commit to a service..
Good luck....Nomess
Posted on Sep 09, 2010
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Elba by f & p wa65tm leds 3,6 &8 flashing
That is fault code 41
41. (00101001) Temperature Sensor Fault (Thermistor)
The temperature sensor is measuring temperatures above 110oC. The fault is probably
due to a short circuit in the sensor line. This fault is only applicable in the GW models.
Primary Source: Thermistor.
Action: 1) Check the connection from the thermistor the Motor Control
Module
2) Check the resistance of the thermistor. It should read 12.5k ohms
at 20oC. Replace if faulty.
3) Replace the Motor Control Module.
Jul 10, 2012 | Fisher and Paykel Washing Machines
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
Mar 27, 2011 | Fisher and Paykel (IWL12)
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Have a fisher & Paykel GW 501 - u Washing Machine which has gone dead. No power is coming and the diplay p.anel is also dead
Go to similar problem posted by ronnelini on Sept 8 2008, and see my suggested solution.
If you're lucky it could be a quick and cheap fuse replacement.
Good luck.
DIY Eddie.
Aug 10, 2008 | Fisher and Paykel Washing Machines
Washing Machines Logo
81 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
