Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
The water dispenser stopped working. What could be wrong?
  • 15,935 Answers
Most likely the micro-switch at the top of the dispenser arm has failed.
Although the onboard relay might be shot too on the main board.
You'll need to do further testing to determine the root cause.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 09, 2010
Whirlpool Duet with precision dispenser. My soap dispenser is not dispensing. Any ideas on what would cause this?
This could fix the problem but take the dispenser out and clean it . Slot of times it gets built up with soap and stops working
Oct 08, 2015 | Washing Machines
How to fix my Refrigerator water dispenser?
This is a duplicate post. To see the original post Click HERE
Water to the ice maker and to the dispenser are turned on and off by a coil on the dual water control valve. Unfortunately these coils cannot remain on for long extended periods of time. If the coils remain on for extended times they heat up and it's very possible that the coil on the water control valve for the dispenser has burned out. I'll get the part number and a description photo for you if you would like. I'm here and available for questions if you need any answers Thank You, John T. Appliance 911
May 08, 2014 | KitchenAid Refrigerators
How to fix my water Dispenser on my Kitchenaid kscs25ftss02 refrigerator?
Water to the ice maker and to the dispenser are turned on and off by a coil on the dual water control valve. Unfortunately these coils cannot remain on for long extended periods of time. If the coils remain on for extended times they heat up and it's very possible that the coil on the water control valve for the dispenser has burned out. I'll get the part number and a description photo for you if you would like. I'm here and available for questions if you need any answers Thank you John Tripp
May 08, 2014 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser stopped working. Ice maker works.
Some of these ge frig have a problem with water freezing inside the door and so the water dispenser wont work. only way to be sure it to turn off your frig for about a week and leave the doors open. plug in then try the water dispenser. if this is the problem call g.e. you will need a special kit to solve this problem. it dispenser still doesn't work replace water valve!!!
Mar 22, 2010 | GE Refrigerators
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
