Question about GE Americana A4425GDTWW Side by Side Refrigerator
Water leaks from bottom of refrigator - GE Americana A4425GDTWW Side by Side Refrigerator
  • 5,081 Answers
Pulled out the bottom white tray that is under the wire shelving and at the back of the freezer is a small hole. Pour in a cap full of bleach and then 1 cup of boiling water. There can be condensation builds up and clogs the hole.
Posted on Sep 09, 2010
Water accumulating in bottom of refrig.
What is your model number? Every different model leaks differently but the same reason (defrost drain frozen shut) causes water to appear in different places in different models. Click here=> Leaking Refrigerators
I'm here should you have question, Thanks, Sea Breeze
Oct 11, 2015 | Refrigerators
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
Refrigator icing at bottom then leaking
bad door seals causing condensation and water accumilates in fridge
Aug 25, 2014 | Whirlpool Refrigerators
Water is running out from the refrigator and i cannot find any leaks. this happens at random once a week
It comes from your refrigerator's water cooling tank which situates at back bottom.
Aug 09, 2012 | Kenmore Refrigerators
WATER LEAK SAMSUNG RB215LASH
When water is leaking inside of your refrigerator, the problem could be as simple as condensation from humidity or a worn gasket, especially since you purchased your refrigerator used. The problem could also be a clogged drain or frozen evaporator.
To help you determine the problem, along with solutions that you can use, check out Refrigerator leaking water inside for some simple troubleshooting steps. I hope that helps!
Aug 02, 2012 | Samsung RB215LASH
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Water is leaking from bottom on the side of
sounds like you may want to check your condensation pan which may be full and causing overflow each day.
Aug 14, 2009 | Amana ABB1927DE Bottom Freezer...
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
GE Americana A4425GDTWW Side by Side Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
