Question about GE GSH25JFR Side by Side Refrigerator
Fridge just quit. No fan, compressor, or ice / water. The only thing working is the lights. I can here something ticking from behind the back panel???
  • 121 Answers
This is going to be the main board. Pull it out and remove the cover off the board. If the noise is comming from there then you know the board is bad. This page should help more http://www.appliance-repair-it.com/GErefrigeratorrepair.html
Posted on Sep 09, 2010
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
My fridge light and digital readings turn on and off and the fridge doesn't stay all that cold. My freezer light is always on but the food is not staying frozen. The ice maker isn't making ice.
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck.
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Freezeer and fridge quit working
It's possible that the Adaptive Defrost Control part number 61005988 has your compressor shut down. It is also possible the temperature control is defective. Jumping the 2 wires behind the control will answer that. And its also possible that the start capacitor, start relay and overload has failed on the compressor. I would like you to unplug and examine the ADC and also need to pull away from wall and remove the cover over the compressor so you can feel the top of compressor. Is it warm, cool or too hot to keep your hand there? Sea Breeze
Sep 19, 2009 | Maytag 22.6 cu. ft. Side-By-Side...
2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Aug 18, 2009 | Refrigerators
Ice maker not working and Freezer not keeping things frozen.
Aug 17, 2009 | Refrigerators
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Kenmore fridge
First we need to see if the compressor is running.  Pull the fridge out take off the lower panel on the back and see if you can hear it running.  Also, need to know if freezer fan and fan by compressor is running.  Check for thick frost build up on back panel in freezer.  Let me know what you find.
Oct 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint Frige
The main computer is bad. the small square panel axcess it. Had 2 do this same thing.
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
288 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
