Question about Grundig S350 AM/FM/SW Radio
I need to replace my antenna on my Grundig S350DL shortwave radio. Where can I purchase a new antenna?
5 Suggested Answers
SOURCE: users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Posted on Feb 28, 2008
SOURCE: Grundig S350DL needs a am aerial to bring in the
1. run 18 gauge wire (buy in auto parts shelf), after stripping plastic (about 1/2 inch) away from wire inside. Clip where RED clip is, on back of radio. Need about 6 to 10 feet. Run wire in upwards direction from radio. At other end of wire, strip enough to make small loop back onto itself. (terminates the wire.) Run another length of same wire from BLACK clip on back of radio, strung along floor of room - 6 feet, maybe. Yes, hide it if it does not please somebody's eyes. Now, you have an AM external antenna.
2. Go to E-Bay, "slinkyantennas". They have a very good-looking, and performs for DX'ing antenna. Use same wire from RED clip, stripped, for alligator clip from 'slinky' shop's antenna to grab hold.
--With s350dl (NPR version-before major t-storm did kaputs, learned good lesson ... always use batteries, not A/C), and slinky pvc-style antenna with ground wire, was able from Central Louisiana, to pick up KOA from Denver!
Posted on May 08, 2009
kb8dns
  • 494 Answers
SOURCE: broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
Posted on Feb 14, 2010
SOURCE: Looking for inexpensive shortwave antenna for
Simple wire can make a great antenna, and it's relatively inexpensive. I've had the best shortwave and AM reception thus far using a long loop (actually a rectangle) of copper wire as an antenna (but folks shouldn't try a loop with some radios designed for use with powered antennas without inserting an appropriate capacitor in series). If you do try wire, you would want to try to make the loop shape as large as possible, and connect the ends of the wire to your radio's antenna connectors.
Posted on Apr 08, 2010
Manual for grundig 750 radio
Here is a link to the manual for your radio.
http://www.etoncorp.com/sites/default/files/GS750_Manual.pdf
Dec 11, 2014 | Grundig Eton Satellite 750...
I just purchased the G6 Aviator. The FM band works well, but none of the AM or shortwave stations get reception. I have tried the antenna up and down, indoors and outdoors with no success.
It sounds like the whole am band is not working which includes the shortwave bands, there is no remedy to correct this and is clearly a manufacture defect. The best solution is return the radio because there is nothing more that can be done in it's present condition.
Mar 03, 2011 | Grundig G6 Aviator (Buzz Aldrin Edition)...
Looking for inexpensive shortwave antenna for use with Grundig S350 AM/FM Shortwave Radio
Apr 06, 2010 | Grundig S350 AM/FM/SW Radio
Broken antenna on grundig mini 300 radio
Feb 14, 2010 | Grundig Mini 300 AM/FM/SW Radio
We have a Grundig S350DL radio that was my father's. There is no manual. FM works great. Can't get AM. Radio turns off on its own!! Any suggestions?
The problem you are having may be due to some configuration settings (such as a timer). Not dtecting the AM signal, may be due to interference from power lines. To improve AM reception (if there is something to improve) one should rotate the radio to orient the internal ferrite antenna. Using the radio close to a window can improve reception.
To enable you to diagnose the problems that may be due to some configuration setting I give you the link to the radio's manual.
Hope it helps.
Nov 08, 2009 | Grundig S350 AM/FM/SW Radio
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
Feb 28, 2009 | Grundig S350 AM/FM/SW Radio
I bought a Grundig S350DL for my husband for his birthday from Radio Shack. The floor model was the last one available so I bought it. The sales person said it was warranted the same as if new. He had...
Despite their renouned customer service, the folks in Palo Alto do get forgetfull on occasion. I asked for a new manual and had to call twice.
Call them again. The worst scenario is you wind up with two!
Oct 11, 2008 | Audio Players & Recorders
Users manual for the grundig g5 shortwave radio
Jan 24, 2008 | Grundig YB 400PE AM/FM/SW Radio
Grundig S350 AM/FM/SW Radio Logo
650 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
