Question about Samsung WF328AA Front Load Washer
Need instructions to replace door-diaphram, part DC64-00802A
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 09, 2010
Need 2 replace accelerator pump diaphram 4 holy 64-3262 carb would like visual breack down
Please watch the Holley instructional video on the replacing of th epump in any Holley series 4 barrel.
Click HERE
Jul 12, 2012 | Dodge Cargo Cars & Trucks
I rebuilt the zama carb but it will not run for more than 30 or 40 seconds what did i do wrong
There are plenty of things you may have inadvertently done wrong, start first by checking fuel to the carb, replace the fuel filter in the tank, check the fuek hose up to the carb for signs of leaks, if all ok, re check the carb, on the pump side it is very importent the diaphram goes against the carb body followed by the gasket and the cover, this is because there will be two small flaps on the diaphram that act as non return valves, so must be against the carb body, there will also be a filter under the diaphram, this should be replaced, on the metering side of the carb it is very importent that the gasket goes against the carb body followed by the diaphram and cover, this is because the gasket is used as a spacer if not there the diaphram will be too close to the metering lever and it will flood, under the diaphram will be the metering lever, needle and spring, make sure this all moves smoothly, the metering lever should be level with the sides of the carb body, there will also be core plugs pressed into the base of the carb, these will be covering the jet holes, dirt can accumalate under these, however you need to pearce the plugs to remove them, and replace with new.
Aug 22, 2011 | Homelite Garden
Choke seems to be on... runs very rough....
There are several ways to do it
a. Check carburetor if not clean pump it on the intake if that not solve try to clean it. with Lacquer thinner to dissolve the dirt.
b. Check spark plug if some are not working. In checking try to pull one by one the high tension wire and listen if the sound vary if the sound remain when pulling one wire mean you have problem with your spark plug. So replace all spark plug with the same spec.
c. or lost compression on cylinder.
d Check if you fuel filter if some dirt and replace it.
e. Clean your air filter with compressor or replace it
f. Check the clearance to the Contact Point it must have 1 mm or .8 mm spacing when not at firing mode ( just like the thin of the hacksaw blade the space of the gap of the contact point.)
Aug 12, 2011 | 1984 Jeep CJ7
Hard to press and a air sound
booster diaphram has failed. Replace brake booster. Let me know if you need instructions, and thanks for using FixYa.
Feb 06, 2011 | 2003 GMC Sonoma Extended Cab
Won't start. possible diaphram problem?
Chainsaw carbs are all position pump carbs, and do have diaphrams, there will be a pump diaphram, and a metering diaphram, the pump diaphram pulsates via either a hole through the cylinder and induction block, or a pipe from the crankcase, the negative and a positive pressure produced as the piston rises and falls is fed into the carb, this diaphram shoud be flat show no signs of blistering or cracks, under this diaphram is the main inlet screen, this should be clean, any doubt and it should be replaced, the metering diaphram controls the amount of fuel allowed into the metering chamber, it should also lay flat and be supple, the metal disc in the middle should be flat and not distorted, both of these components are very robust and only need replacing if they are damaged, worn or have become stiff due to fuel attacking the material.
Feb 02, 2011 | Garden
Why do I hear air under my dash when I push the break on, and the breaks are hard to push.
your booster diaphram is torn, and you need to replace the booster. If you would like instructions on how to replace it yourself, please let me know.
Nov 28, 2010 | 1992 Honda Accord
Heater will not switch to floor vent
Heater door diaphram not working, either has a vacuum leak or the main control needs to be replaced. The A/C-Heater switches work with both electricity/vacuum at the same time, the switch may be bad, replace it.
Oct 20, 2010 | 2003 Chevrolet Blazer
When i start my truck the brake pedal goes to the floor and a can hear the vaccum. when i hat the gas the pedal releases a little?
Your power brake booster diaphram has torn. Replace booster unit. Let me know if you need instructions.
Sep 20, 2010 | 2002 Ford F250 Super Duty SuperCab
Water run over top of tub
What has happened is your water diaphram has gone bad. If you look at your control board you will see your water select switch. This is the water diaphram. Remove the two side plastic covers from the control board. Remove the two screws underneath the plastic covers. Flip control board over. Make sure the diaphram hose is still connected before you order a new one. If the hose is connected at the diaphram than the diaphram is bad. To replace the diaphram, Unplug washer, remove hose, plug, and twist to remove. I hope I helped you.
Aug 31, 2010 | Kenmore Washing Machines
2004 Mazda 3i 2.0L -- Intake Manifold
I have had the same problem at almost exaclty the same milage. 2004 Mazda 3 3 door hatchback (5 door sedan). I was told by the service manager that there is a valve in the manifold that fails and starts flapping, sounded just like a collapsed lifter. I think this should be covered under warranty. If not the mfg warranty the emissions? .. good luck.
Nov 25, 2008 | 2004 Mazda 3
Samsung WF328AA Front Load Washer Logo
725 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
