Question about Toys
Have gemmy halloween butler and head and mouth move, but no sound, volume is on, have made sure head is on right
5 Suggested Answers
SOURCE: Gemmy Santa Bear mouth does not move
The repair listed is just the start. You can, with a lot of careful work, remove the bottom of the mouth, but your work has just started. You will then have to remove the rod that holds the mouth rod to the mouth slide lever "spine". It has a small spring at the top and I found it easier to disconnect the spring prior to repairing the unit. It is glued in quite well so I suggest a Dremel tool to cut the sides off which you will enable you to remove the rod. Then you can remove the head from the spine without difficulty. Now you will see that the problem is as stated, the string that pulls the mouth open has separated from the motor shaft. The cause of this problem is that the grease that the mouth slide lever rides on has migrated to the string, and then, softened the glue, which allows the string to separate from the motor shaft. Now, clean the shaft and replace the string. The original string is nylon. You should use similar material, NOT cotton string or a rubber band. You can't use the old string as it is soaked with lubricant. Use a good super glue to bond the new string to the motor shaft. Next, test the unit to make sure that the mouth slide lever operates properly. Reassembly of the unit would be: remount the head to the neck, then reattach the mouth rod to the mouth and then reattach the mouth and rod to the mouth slide lever.
Posted on Aug 29, 2009
  • 1340 Answers
SOURCE: I have a gemmy michael
It sounds like either the arm disconnected from the gear,or it is a plastic gear which has been stripped.There may be a simple clipring holding the arm to the gear which has popped off also.It would look like about a half circle which may have a couple of tabs on it to be able to open it wide enough to remove or put back on.Is there any way to access it that you can find?The front half and back half may be screwed or clipped together,it sounds like how it would be built anyhow.If you can get to it,you should have either answer just by being able to see it.Just make sure it is unplugged while working on it.Do not just turn it off.Once you find something,try to do whatever it takes(should be one of the above suggestions),then plug it in and turn it on to check it.Good luck! Greg
Posted on Oct 28, 2010
SOURCE: Our Singing Bing Crosby Santa doesn't move his
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
Posted on Jan 16, 2011
SOURCE: lifesize leatherface by gemmy.Shoulders & head
Would you be interested in selling this ?
Please let me know and Thank you !!
Rob
Posted on Dec 06, 2011
My gemmy dancing santa bear wont move any more i need help
I is very good that the http:www.molitop.com goods,You can take a look at Lady Gaga Halloween Costume Kit, you should be satisfied.
Oct 15, 2012 | Gemmy Life-Sized Animated Santa
Gemmy Dean Martin Mouth doesn't move. I took the head off by removing the 4 staples and can see the internal parts. There are 3 phillips head screws at the base of the head and 2 holding the plastic post...
Remove the staples to loosen the mechanism from the neck.
Remove the two screws holding the post to the mechanism base with a small Phillips screwdriver. Push the mechanism mouth out as much as you can to reveal the mouth post base. Using a hairdryer, heat up the mouth post glue and pull gently to remove the mouth bottom. Pull the mechanism out. Take off the spring. Replace the string with similar string. I would also recommend buying a new motor on ebay for $3 from China. You can get him singing again.
Feb 16, 2010 | Gemmy Toys
Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
Two broken gemmy dean martin dolls how can i get them fixed
i looked through my local yellow pages and called a few electronic repair places. i finally found someone willing to take a look at it. sure enough they were able to fix it.i picked one up today and dropped the other off to see how they could do with this one now too.thanks you dolores metacarpa
Jun 10, 2009 | Gemmy Rocky Balboa Big Head Animated...
I would like to first tell you what the problem is with either your Bing or Bear head. Inside the head is a motor that works the mouth. On this rotating motor is a pulley type system, which has a twine or you could call a heavy string piece. It is attached to the motor, and when the is activated it rotates the thread round the spindle on the motor and the mouth operates.. It is quite a difficult to take this head apart. I worked on my Bing for some time to find out this problem.. The string comes away with use and of course time, that is is why the mouth no longer moves. If you wish to try and repair, you first have to remove the head from the base. If you look there are 4 heavy duty staples just round the collar neck area. They will come out with a small head screwdriver or something pointed. Just work it slowly under till staple raises up, then just pull it out. Once they are all removed the head should be loose. This is only to give you access to seeing the internals firstly. Now comes the hardest part. The soft moving part of the mouth needs to be removed. You need to work it of slowly as there is a glue base on it, so care is needed here and can take time. If you managed this all is left is the metal pin it was on. Now inside is the plastic unit that moves the mouth this is glued in which is the main problem. And this is the issue, it is pushed on and the only way is to remove is to have a precision head screwdriver and work it off... Best done by someone who is quite good with their hands and very patienced. Because it may break. Took me severals hours to remove. When you get it off the internal workings will come out of the head. There is no other way of doing this. Having the head loose allows you to look at the piece and the workings. A small torchlight held by someone is best as you work out the mouth fitting.....As i said it is no easy job and took me long periods of time to get to this point. I wish you all the luck in achieving this.......
Dec 15, 2008 | Gemmy Rocky Balboa Big Head Animated...
Toys Logo
120 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
