Question about Traxxas Rc Revo Nitro Monster Truck
My Traxxas Revo 3.3 will not shift into 2nd gear. I tried to adjust the tranny to make it shift sooner to no avail. It revs at max 50 000 rpm but will not shift. It overheats because it won't shift and I can't experience the models top speed potential. What should I try next? Even during the break-in process, it never shifted into second and that is with the tranny at factory default settings! The model is only two months old and has less than 12 runs on it... Please help. It would be so very much appreciated.
  • 637 Answers
Readjust the spring engaging the clutch. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Posted on Nov 22, 2014
  • 10 Answers
SOURCE: Traxxas Revo 3.3 shifting problem
you might need to reset the opti drive. turn the power on with the engine still off and hold down the optidrive button for 5 sec. see it that works.
Posted on Jul 07, 2009
  • 56 Answers
SOURCE: traxxas revo 3.3 running problems
Maybe running to lean or to rich. When you accelerate put youre hand where the exhaust is and you should get a light spraying of unburnt fuel over hands(lovely!). If you do you may be able to screw in high end needle in a bit and i mean just a bit. If you hear the engine note raise a bit with a slightly higher pitch then you are running to lean and you will want to unscrew the high end needle valve asap.
Also check youre idle screw and make sure thats not closing the carb and stopping any airflow into engine. Let me know how it goes.
Posted on May 30, 2010
n8binc
  • 33 Answers
SOURCE: manaul for a traxxas t max
I'm not sure which model of T-max you have, but this page has a list of all the manuals including some t-max models, and the Jato, they're listed on the left side. Can't miss it.
http://www.traxxas.com/support/kb_search.php?action=artikel&cat=165&id=518
Posted on Jul 12, 2009
  • 3 Answers
SOURCE: Traxxxas Revo 3.3
You need to adjust your idle, what's happening is every time you apply your brakes you also close your carby throttle, your truck is not getting enough fuel because you have your idle set a fraction low. Simply turn or your electrics then take your air filter off, now adjust the screw under your carby until you have 1-2mm opening when you apply your brakes.
Posted on Jul 28, 2009
  • 88 Answers
SOURCE: Traxxas Revo 3.3 engine cooling head
Remove the glow plug wire and there are just a few bolts that hold the head on. Just make sure you install the new head with the head shims like they were under the original head.
Posted on Dec 10, 2009
Why will rpm rev fine on 1995 chevy Silverado 4x4 till its put in gear then it wont rev past 2100 rpm
it sounds like its is shifting strange it could be the torque converter or something inside the tranny making it shift sooner than wanted.
Oct 22, 2013 | Chevrolet Silverado 1500 Cars & Trucks
94 chevy v8 350 4x4 1500 jumps when I put it in gear and will not change into second gear until rpm's are maxed!
If fluid level in trans is ok it sounds like clutches in tranny or internal pressures are going bad.
Dec 07, 2010 | 1999 Chevrolet Silverado 1500
Goes from overdrive inti 2nd gear can not get out
the front pump and 2-3 clutch packs are weak createing a internal shift failure the tranny needs to be otrn down and fixed
Jan 20, 2010 | 2002 Chrysler 300M
1996 gmc suburban transmission shift problem
96 gm trucks had a proble with third gear burning out because of a ground issue from pcm..there was a bulletin for adding a new ground for third gear control circuit...aftermarket trans shops do not remember this problem and it is often overlooked..take to local dealership and you should be able to get problem resolved
Dec 27, 2009 | 1996 GMC Suburban
My revo 2.5 will shift/not shift
I am not sure on the Revo, but the shift point on a T Maxx is adjustable. There is a small rubber plug on the transmission that you remove and you adjust it with an allen wrench. If you have a manual for the truck it will have a section in it that shows you how to do it.
Aug 20, 2009 | Traxxas Rc Revo Nitro Monster Truck
95 dodge dakota having hard time shifting.
Try a tranny service change a place that changes the filter the pan gasket and fluid not some of these quick places that just drain a couple quarts out of the tranny lines and thats it that wont help but a complete tranny service should help.
Jul 30, 2009 | 1995 Dodge Dakota
Hard shift from 1st to 2nd, then 2nd to 3rd.
Dont think they changed it yet but the older chrysler units had a rod that went from the throttle linkage to the transmission (maybe a cable now)...If you lengthen the rod it will increase shift pressure and give you an earlier shift.
Jul 17, 2009 | 2002 Dodge Dakota Club Cab
Shifting problem
sounds like it may be either a converter problem or u got some bad clutches in third in the case you need to go to a tranny shop.
Jan 27, 2009 | 1998 Honda Civic
Traxxas Rc Revo Nitro Monster Truck Logo
1,214 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
