Question about John Deere Garden
The charging system is not working new battery keeps going dead. How do I troubleshoot to find the real problem?
    President:
  • 1,627 Answers
First off ,i'm only going to give you a general test to do,this is because you did not give an exact model so i can't give an exact answer.Most lawn tractors have a stator,under the flywheel of the engine and the wireing will come out from under the engine cover.Locate that harness(it should have 2 wires in it,sometimes three)and then follow the wires to a plug.Unplug the wires and with the engine running,set your multi-meter on a/c voltage and with the engine idling you should have over 20 volts of power coming out of the stator,if not,replace the stator.If you have power coming out of the stator the next thing you need to check is the power supply to the regulator,keep following the harness and it will lead you to a square box(the regulator) with no less than three wires in it.One of the wires should have 12v dc at all times,if so replace the regulator,if not repair the wireing.Let me know if this helps,if not please give me a tractor model number and the results of the above tests.
Posted on Sep 09, 2010
Battery dead
With a meter, the battery should have 12 volts at rest. With the engine running and no accessories on, the charging system should be producing 13.5 - 14.5 volts.
You could have a battery problem, a charging problem, or something draining the battery when the engine is off.
Jun 22, 2013 | Cars & Trucks
Batter keep going dead
Check you charging system, with a volt meter is should show between 13.5-14-5vdc at the battery with the engine at 2000 RPM. Test your battery for load capacity and dead or weak cells...1 dead cell will drain the others. Hope this helps.
Jul 13, 2011 | 2004 Yamaha YZF-R1
I got a 2008 cbr 600 rr I put 3 new battery on it and they keep going dead they are kinda cheap battery my bike will run abt 2 hour on a new battery then it goes dead and wont push start and it makes a...
Put a charger on the battery for two or three hours. Now start the bike up and use a voltmeter to measure the voltage across the two battery terminals while the engine is running around 2000 rpm. The meter should read around 14 volts. If not, the charging system needs to be checked. If the charging system is working properly then yes, something is draining the battery. You will need to check all the wiring and switches to locate the source.
Apr 13, 2011 | 2008 Honda CBR 600 RR
My car won't start and it sounds like the battery is dead however i cannot hook up a jumpbox to it because the red has a casing around that makes the area to confined to hook it up. its a 2005 buick...
The cap on the positive battery cable can be pulling out and it has a thearther to not lose it. Some on them have two battery cables and their well known to get corrosion under the bolts and bewteen the cables and the side of the battery the bolt head is 5/16 or 8 MM and needs to be taken apart and all cleaned and connected it's best to charge a low battery or change it as the altenator can go up in smoke after a few minutes charging a dead or low battery after a jump start. If nessary connect the jumper car with it running and let it sit there charging for awhile, then start the dead car and still leave it connected to stableize the charge and not ruin either car. Once running take the car to a parts store or service center and have them test the battery and the charging system. You can aquire a battery charger if you can get an extion cord to the car and charge the battery and in a few hours the car will start if the battery is any good and the charger works correctly. If the battery is real cold and real dead it's possible the battery can explode if jumped off wrong or making a spark. Be real careful with low and dead batteries as they can spray acid in your eyes and on your skin and sparping lots of water on yourself in the cold is a bad deal. and lots of water is the only good way to deal with the acid.
Dec 16, 2010 | 2005 Buick LaCrosse
I have a HP Pavilion G70-250US Notebook that suddenly starting having USB recognition issues. It started with the USB receiver for my wireless mouse. Suddenly it stopped working and I started getting...
no operating system even stated.
Xp/vista/w7/w9/w10/ linux ,what.... must we guess?
is your internet connection working? it must or PNP will be near brain DEAD ,do that first.
ok guess w10.
why not see if OTHER USB works first
barrow a real mouse not that battery dead wireless wonder mouse?
get a real mouse
make sure that works
then put in a new battery in your wireless mouse
RTM it tells you how
USB tests, all so obvious.
use real desktop key board , that work
or USB memory stick , add file to it, see other files you have there>?
only clues here is USB dead, 2 months old.(means new? or new to you?)
next,
in w10
go to CP
then go to device manager
be ONLINE
see yell or red error there that driver stack?
bingo bad driver
reload any that are bad.
end story
google how to reload a windows 10 driver, be like 10,000,0000 hits.
Mar 15, 2017 | HP G70-250us Notebook
Battery keep going dead, has new battery
Have you checked to see if the alternator is charging ? Run a volt meter on the battery with the engine running, have to have more than 14 volts. If 13 or less, then replace the alt.
Jan 18, 2010 | 2003 Chevrolet Venture Passanger
Battery keeps loosing charge- kymco cruiser 125, 2005
I had this exact same problem on a hipster 125, it was a faulty regulator module ( mounted under the seat) I also found a short circuit (somewhere) in the wiring loom between the regulator output and the chassis (probably what killed the regulator in the first place!) I cut and replaced the entire wire to save removing most of the loom and after testing reg to ensure it was dead i fitted a new one (about £60) bike charges and runs like a dream now even with fully lights approx 80% of the time. good luck
Jul 14, 2009 | 2005 Kymco Hipster 125
My new battery keeps draining
you could have a fault on your regulator/rectifier a chech with a multi meter will tell you. also check generator output.
Apr 11, 2009 | 1988 Honda CBR 600 F(1)J
Motorola razr battery problem
The only solution is to get a new battery. When you do, charge it completely when you first get it, then discharge it until it dies. This will maximize the life of the battery.
Nov 29, 2007 | Motorola Mobility RAZR V3
Garden Logo
455 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
