Question about Crown CE2000 2-Channel Amplifier
Fault light - Crown CE2000 2-Channel Amplifier
Malfunction indicator light not commicating
Vehicle fault lights is caused by fuel emissions system more commonly, you at the time of fault lights to start vehicles, car, start, out after three times in the launch vehicle would you see if the trouble light or light, or light up you need in a timely manner to the store check the fault code, is a problem of engine or the sensor fault, or light may be occasional failure can need not in time to the shop to check the sohu auto q&a platforms,auto diagnostic tool.
Mar 14, 2013 | Cars & Trucks
Abs fault light, engine management light, parkbrake fault (won't go off) DSC fault light, air suspension fault, 2003 Jaguar 3.5 SC V8, ah also discovered water ingress in boot, quite a lot!!, only fault...
try disconnecting the battery both leads and join them together for 5 mins and see what happens cannot find this fault code in teh jaguar OBD codes so consult with teh code reader manufacturers
Feb 08, 2011 | 2003 Jaguar XJ-Series
My 2004 ford taurus is 98 000 miles and the engine light is on the dashboard just now what i should do ?
You will need to put your car on a diagnostic fault code reader. The engine malfunction light will come on if there is a fault with the emissions if it runs ok and isn't misfiring it's probably a oxygen sensor fault or a catalyst fault. The light won't go out unless the fault is cleared
Oct 04, 2010 | 2004 Ford Taurus
1998 chevy monte carlo check egine light wont go out evevn after computer download
if the light stays on, this means the computer has detected a "hard" fault. This means that the fault is present and is detected during the computers power up self test. You need to follow the diagnostic procedures pertinent to the faults given. the light will stay on as long as the fault remains. Simply downloading the fault codes will not put the light out.
Jan 05, 2010 | 1998 Chevrolet Monte Carlo
Electronic Ignition Fault Light On
It is probably due to a faulty sensor somewhere, but without proper diagnostic equipment it is virtually impossible to tell which one.
A modern fuel injected engine will have sensors to monitor throttle position, manifold pressure, coolant temperature, air temperature, crank speed, camshaft position, exhaust gas oxygen, pre-ignition, etc, etc, etc.
Diagnostic equipment will be able to read the fault code from the vehicles computer and tell you where the fault lies.
The light cannot be reset manually. It will go out once the fault has been rectified.
Hope this helps!
Jun 20, 2009 | 1998 Volvo S70
Flashing glow plug light
sounds like a glow pug fault.it will flash if one glow plug has a fault.
Jun 03, 2009 | 2003 Volkswagen Golf
Check engine light
BMW engine light
Comes on if DME engine management system self diagnostic fault detected. Will stay on until codes are called up and memory erased.
With OBD read the code as follows. Turn on ignition key, press accelerator pedal to the floor five times within 5 seconds. The check engine light will remain on for 5 sec , blik off, come on for 2,5 sec, go off for 2,5 sec and fault code will begin to flash. If more than one fault exist 2nd fault code will be separated by 2,5 sec pause. after fault codes there will be a 0.5 sec flash and light will remain off. to read codes again do procedure again.
Canceling of codes. make sure fault code is present (short blink and light goes out for long period), depress throttle pedal for at least 10 sec. read fault codes again and check for code 1444 (no faults stored.)
Check also the following, fuel pump, oxygen sensor, fuel injectors, engine coolant temp sensor, idle speed control valve, mass airflow sensor and too many other things.
Apr 12, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
Focus brake light fault
http://www.diyautoparts.com/search/parts/2006/ford/focus/brake-light-switch.shtml
Jan 16, 2009 | 2006 Ford Focus
Wont start mornings when warm starts good for a few times then wont again an also got i think engine management light come on in the dash when runing it comes on an off about half an hour apart
hi you need to get a reading off a fault code reader to find out what is causing the light to come on the engine manament light works off detecting not an individual fault it has to recieve this fault on 3-4 occassions before the light comes on if it doesn,t recieve a fault reading in a certain period of time it will presume the faults been fixed and the light goes out but 30 min period seems not enough time to for a reset the fault code reader should be able to store the fault code even ifs its not happening at the time but would be better if you can get the reading while the light is on yates210456
Oct 01, 2008 | Mitsubishi Passenger Cars & Trucks
Is this the same light for the emergency brake?
Jul 03, 2008 | 2004 Ford Focus
Crown CE2000 2-Channel Amplifier Logo
97 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
