Question about Lexmark X2600 InkJet Printer
Do both ink cartridges need to be installed inorder for the printer to work
  • 823 Answers
Yes both cartridges have to be installed in order for the printer to work at all times.
Posted on Sep 09, 2010
Testimonial: "thankyou...this was helpful seeing that there was nothing addressing this in their instructions and only one cartridge came with the printer. "
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
I only want to scan but need a new cartridge - do i have to replace cartridge before scanning is enabled.
You will need a new cartridge before you can scan.
What you could try is to remove both ink cartridges.
Turn printer off and unplug from outlet.
Wait at least 30 minutes, this will let the printer to reset
Turn your ink cartridge upside down for 2 minutes before installing.
This will let some of the ink from the bottom to reach the printhead.
Plug printer back in and turn on and install ink cartridges.
This might work if your printer only detected a low ink condition at first.
For the scanner to work, the printer must have no alarm.
Jan 14, 2011 | HP PSC 1315 All-In-One InkJet Printer
Install black cartridge, but will not print
Lets do it this way. Follow these steps again carefully and try to install the Ink.
Introduction
Follow the instructions below to replace the ink cartridges.
Replacing the ink cartridges
1. Verify that the unit is on.
2. Open the ink cartridge door.
3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
1 - Ink cartridge latch for the black ink cartridge
2 - Ink cartridge latches for the color ink cartridges
NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging.
6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
7. Press down on the gray latch until it clicks into place.
8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
9. Close the ink cartridge door. Print a test page.
If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
Shut down your computer and restart it.
Re-install the printer driver/software from the start as you did when you bought it.
Good luck
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart d7368
Here is the document that i want you to follow correctly inorder to solve your issue.
CLICK HERE TO VIEW==>> DOCUMENT
Please let me know the outcome after following the document.
Thank you so much.
adonscott
Jul 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Error ink system fail
here are the steps that i want you to follow inorder to solve the issue.
Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
Please give me feedback if the steps resolve your issue or not so that i can go ahead and find another solution of your problem.
Thank you so much.
adonscott
Jun 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Can't get my printer to print
Hello lilltlellulu2,
This is Enday, to solve your problem, try to check if you have installed the ink cartridges properly... If you have installed the software for the printer ,you must restart your system unit inorder to take effect on what changes you made..so as ther hardware to work.
Now, after restarting, click on the control panel, then printers..as you can see your printer installed,,right click on the printer icon>properties>print test page...
Just see if its working this time...
Thank you... and Good day...
Enday
Jan 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Ink cartridge red light
need original canon ink cartridge not generic
Jan 02, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Lexmark X2600 InkJet Printer Logo
223 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
