Question about Bang and Olufsen Beocenter 9300 Shelf System
Our beocenter 9300 will only play at a low volume (of about 4 bars). You can increase the volume a bit, to about 8 bars, but not for long. The volume drops to about 4 bars in just a few seconds. What is an audiophile to do?
  • 122 Answers
TRY REMOVING THE SPEAKER CABLES AND LISTEN ON HEADPHONES,IF THIS WORKS THEN SUSPECT SP WIRING BUT MAY STILL BE AN INTERNAL FAULT IN UNIT EITHER OUTPUT OR P SUPPLY.
Posted on Nov 21, 2010
'Beocenter 9000' sounds problem
Hi talenso,
as the beocenter 9300 i assume its at least 7 years old. This model has 2 transformers in them one for when it is on standby and one during operation. I suspect one of these has degraded over time.
My best advice is see if you can go to your local store and buy one of those power boards that regulate the voltage coming into the unit. This may solve your problem, but my gut feeling is one of the transformers needs to be serviced.
good luck
smeags.
Jan 08, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 9000 won't play cd,help
The most common cause of not playing cds is c2103 on the pcb under the cd mech.Try cleaning the laser lens also.
Jan 04, 2011 | Bang and Olufsen Beocenter 9300 Shelf...
Black glass control panel has become unstuck; where to get suitable adhesive tape? Ref Beocenter 9300.
unscrew glass panel at back, take all plastic trim off and remove all sticky residue on these and the glass, then use liquid nails sparingly and let dry thouroughly before reattaching (slide panel back on, then put rear screw back in.
Dec 27, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
The sliding cover for the tape player sometimes gets stuck when opening.
if we are talking beocenter 9000/8000/9300/8500/9500 replace belt,clean and lube door guide rails
Oct 19, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Glass panel unstuck
if product is beocenter 9000/8000/8500/9300/9500 remove screw under l/h side of panel, push panel to side and remove.careful to note position of plastic attachments and metal screw socket.lay face down on bench and apply thin ribbon of epoxy resin where double sided tape is,do not clean off old tape.apply glue over top.assemble plastic parts on top and leave to set.refit to machine and refit screw.
Oct 14, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 9300 - doors don't full open
no,motor drive on timeout.usual cause friction between door and guide rails,only way to check is to remove doors and clean/lube door guide pins.this is not an easy job,very fiddly as involves detaching doors from cord drives.you may also have low motor cct supply voltage.
Mar 28, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
18 year old Beocenter 9300 CD won't play most CDs
cd unit unable to read disc,replace or try cleaning laser lens.cd clamper may be misaligned or faulty,check operation in service position(top up).
Dec 18, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
221 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Iluvintage
Level 1 Expert
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
