I have a SanDisk adapter I use in a game camera and when I out it in the slot the pictures do not come up. The computer does not seem to regocnize that the disk has been inserted.
  • 3,083 Answers
First thing to try is to use a different usb port for the card reader.
If that doesn't work, try a different disk to see if the port's working, and the card reader. Next, make sure the card's fingers are clean- clean them with a qtip and 90% isopropyl alcohol. Also, make sure the lock tab on the SD card is not in the lock position. Aside from that, you might have a problem with the card reader itself.
There are memory card utilities on the net, but you have to be able to use a card reader to fix the corrupted cards.
Check to see if your computer recognizes the other usb devices, and if it does, I would think maybe the card reader or disk itself is bad.
Sorry I don't have an easy fix for you, but good luck, and hope this helps.
Posted on Sep 09, 2010
How do i get pictures off my sony memory stick pro duo with adapter on to my hp laptop
You will need to purchase an adapter that will fit the SD card slot or USB connector. When connected, use the computer to open the files from your memory card and save them on your computer.
These adapters are available from big box stores and online from eBay and Amazon.
May 27, 2015 | SanDisk Electronics - Others
I have a Sandisk memory card, and everyone I try to take a picture or delete a picture from the camera itself or on the computer, it wouldn't allow me. This has been happening for over 2 months now and...
Try the locking mechanism on the side. It can lock sometimes if it is loose,as you put it into the slot. If necessary tape it in unlocked mode. It (the switch) will appear on the upper left hand corner of the SD card or micro SD adapter.
Sep 03, 2011 | SanDisk 2GB microSD Memory Card
How do you transfer a photo from computer to sanDisk
Please keep the sandisk in to the USB port of system/laptop,
select the files what you want to send to sandisk, then rightclick on the selection. Then goto "Send to" option. In that you will find your sandisk. Select the drive of sandisk.
System will send the fiels to memory card.
Jun 08, 2011 | SanDisk 4GB microSDHC Memory Card
How do I load scan disk pictures onto computer
If your PC has an SD card reader you can place the microSD card into the adapter that it came with and then insert it into the slot on the PC. The SD card reader will be a small slot usually at the front of the computer. If there is no SD card reader then place the microSD card into the gadget you use it with such as your camera/phone etc and connect the device to your PC using a cable the device came with. The cable will have a USB jack at one end that will fit into the USB ports at the front/back of your computer. Once your device is connected you can follow the on-screen instructions to access your pictures.
May 23, 2011 | SanDisk 1GB microSD Memory Card
Is there some sort of adapter for a sandisk Ultra CompactFlash 4gb, that i can use to put picutres on my computer?
The device:
Belkiin Universal Media Card Reader
Can be connected to your computers USB port and will then allow you to move pictures from the compact flash card to your computer.
After you connect the device and insert the card you will see a short delay and near the bottom right corner of the screen a message will appear letting you know that windows is setting up the new device. Moments after this completes you will see a new window popup asking what you would like to do with the media card. From the list select move pictures to my computer with the Scanner And Camera Wizard. During the move it will remove the pictures from the card and give you more free space for pictures if you click the checkbox labeled Delete Original Pictures.
May 15, 2011 | SanDisk ULTRA II 4GB Compact Flash Card...
I can't use the memory cart!
The adapter simply changes the size of the card to a larger card that will fit into some computers. Some cameras use the tiny card but when you want to play the photos on the computer you take the tiny card, insert it into the larger card, and insert that combination card into the computer slot.
Nov 23, 2009 | SanDisk 2GB microSD Memory Card
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
SanDisk Memory Stick Pro Duo problem
it may be lost, safely remove your hardware befor you get off from the computer
Nov 02, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
MicroSD Card not being read, SanDisk 2GB MicroSD Card
I don't think there is a problem with the card itself. The slot might be dusty. Try and blow into the slot and then blow the card itself.
Feb 11, 2008 | Nintendo DS Lite Console
Cameras & photography
Yes, if the picture frames supports Sandisk or has a slots for that..
Dec 17, 2007 | Cameras
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
