Question about Refrigerators
Burning plastic smell especially in the freezer...I've opened the back and vacuumed what I think is the condenser, and the fan is not running. Should it always run?
  • Refrigerators Master
  • 1,606 Answers
Replace the fan motor . When it stops , you will get a smell . It should run anytime the compressor runs .
Posted on Sep 09, 2010
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
Odd smell when plugged in. smells almost like a lubricant or diaper cream. we've cleaned and bleached everywhere we can. it doesn't smell unless it is running and it is not inside the refrige
in the freezer behind the back inside wall of the freezer there's an evaporator fan motor that could cause this if you were smelling this inside,there's also a condenser fan motor in the back bottom of the machine that blows when it's running,pull out the machine,remove the bottom back panel and check the fan motor to see if any oil is leaking out of the motor.
Sep 15, 2012 | Estate TT18TKXKQ Top Freezer Refrigerator
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
My fridge stopped working. First there was a burning plastic smell, then everything in the freezer defrosted even though the fan kept turning. It sounded normal. There was no frost on the back wall of the...
A burnt plastic smell indicates a failed component. Start where the odor was the strongest and locate the failed part. The hard part is determining the reason for the failure as just replacing parts will not correct the problem. Look at the start relay on the compressor or the defrost components.
Eric
Jan 24, 2010 | Kenmore Refrigerators
Have alful odor in freezer and ref,had some things spoiled and lefted bad odor in freeer and smell went into ref tooked everything out and washed them out good, and put backing soda in but smell was still...
empty the unit and put a dish of charcoal in the frig and the freezer. Let it run for a week and see if that helps. Some odors will get into the plastic and insulation and cannot be removed.
Eric
Nov 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Layed refrigerator on its side to move waited 3 days plugged it in worked fine for 3 days then electrical smell and it doesn'tget cold. can i fix it
Fan motors are great item to give off a burning smell when failing.
You have one in the freezer compartment behind the back panel.
You should be able to hear it when you open the door to the freezer.
A second motor is behind the cover panel at the bottom rear of the machine near the compressor. Failure of either motor can cause no cooling, and a burning odor.
There is a calrod heater located in the freezer compartment behind the real panel that can short and burn, but it would not immediately cause rapid cooling failure unless it burned a hole in the evaporator causing a total loss of refrigerant. ( I've seen it happen, but it's rare). Beyond those items wiring runs throughout the machine and can be suspect especially if the machine was transported on it's side. Refrigerators should always be moved in an upright position.
Nov 02, 2009 | Kenmore 50522 / 50524 Side by Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
