Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser in GE side by side continues to freeze. Temp is set at 4 (of 10) I thaw the line and a day or so later it freezes again...
  • GE Master
  • 1,606 Answers
Install pt # WR49X10173 from GE . This is a waterline heater , to stop this problem . It comes with instructions and is easily replaceable .
Posted on Sep 09, 2010
Water line freezing in door of GSL22JFXJLB Side by Side
the problem is the line is freezing up due to obstruction or blockage. which causes the water to back up and freeze, I have used a blow dryer, hot water, and a soft type long tiny tube or cord like material and even a coat hanger but be very careful, to get inside the line and unplug the obstruction or if u can remove the whole line and replace it? but may be very difficult. why was it pluged? some times pc's of plastic bags, old food particles, etc get into the line, doesnt take much
Mar 11, 2015 | GE Refrigerators
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Frozen water reservoir in GE Eterna refrig model GESL25XGRBS-SS...the water dispenser doesn't work, although the ice dispenser is just fine. We turned off refrig for a few hours and the water dispenser...
According to factory experts, the water line is freezing in the door. There is no easy or cheap solution...they can replace the door for $300 is what I was told. The line is routed in such a way that it is not insulated enough from the cold of the freezer. Take off the bottom fan grill in front, take water line apart and cycle the water. It will pump out but not go through door. Buy a new door or go to the faucet.
Dec 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
FROFEN WATER LINE ON REFRIGERATOR DOOR
it seems to me that the tubing is not properly insulated in the door causing it to freeze you can open the liner and see if it is inside the insulation or lower your freezer section so it does not over freeze thanks from gilles
Feb 22, 2009 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
187 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
