Question about 990 And 950 Responder SST Remote - 7701P
My remote will not do anything. i try to lock my car and it gives two quick beeps three times and im right by the car so im not out of range.
  • 32 Answers
You will have to overide the system with your valet switch, its either a bad brain or bad antenna, its a common issue with viper
Posted on Sep 11, 2010
I had purchased a Durango with a phyton Ron 479vipix and it's not working I know nothing about remote starts I live in anchorage Alaska I really need this hooked up were do I start
Posted on Nov 17, 2013
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
My 2009 Ford Escape remote starter....i click and it beeps once..then beeps three times. Will not start or turn over engine. What does this mean or is there quick fix?.....been working good for 3 yrs.
By some strange reason it happens also if the instrument panel dim light is all way up and you have to keep your dome light switch off or it will light even if all doors are shut. I put the dim light switch into normal position and my remote starter resumed its function! Thanks to F150 forum, I found this remedy there: 2010 REMOTE START
Jan 07, 2013 | Ford Escape Cars & Trucks
When i turn on my playstation3 it shows the ps3 logo when loading up but doesnt come up with the sign in menu or anything?
try restoring your ps3. turn the switch on teh back off then on. then put your finger on teh power button until you hear three beeps. ( not including the one you hear when pressin the power button.) right after the third beep let go and it will turn off. then try again. after the power beep listen for one beep then after that a double beep. it will show a menu of options. pick restore ps3 then quick format. *ALL YOUR DATA WILL BE DELETED BUT ITS THE ONLY OPTION!
Mar 04, 2010 | Sony Playstation 3 (PS3) Console
My Viper 791xv remote isn't receiving the page information from the unit in the car. When I press the unlock, lock, or remote start button, it works, but then the remote beeps as if it didn't work (3 sets...
My battery ran low and I jump started my car which some how caused the problem. My viper technician made me a buy new remote but the problem continued even with the new remote.
Try disconnecting the battery of your car for ten minutes and then reconnecting it. It worked for me. Now i have a extra remote which i don't need.
Oct 12, 2009 | 791XV The 791XV is a 2-way Security and...
Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
Jun 18, 2009 | Adidas Candy Digital watch
Central locking not working on a 2001 Ford Puma
ignition on and off three times, car beeps, press lock button car beeps, remote programmed
Mar 25, 2009 | Ford F Cars & Trucks
Wont recognize gtco digitizer on start up
First reset digitizer and make sure you hear four beeps and only four beeps.
Check the cables from the Quikruler to the interface module, make sure they are in good condition, no cuts, breaks missing pins on connector.
Check cables from interface module to digitizer. A good way to check for an intermittent problem is to bend the cable at different points and check the display on the Quikruler to see if has reset.
Select S01 on the superset code with your stylus or cursor. You get get four sucess tones (beeps).
If none of this works check the firmware version on the digitizer, some J2.0 firmware may become corrupted. When the firmware becomes corrupted, you will hear three(3) medium tones on power-up.
If this is happening it will have to be serviced by GTCO.
Feb 06, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Vw cabrio key remote programming
First, you will need two keys. Put one key in the ignition and turn the ignition to the "on" position (instrument cluster lights come on). Make sure the hood, trunk lid, and both doors are closed. Take the other key and stick in the driver's door lock. Turn the key counter clockwise and hold it in this position until you hear three beeps. Release key but don't remove it. Press the lock or the unlock button on the remote until you hear a beep. Once you hear the beep from the remote, turn the key in the door counter clockwise again until you hear three more beeps. The three beeps are the signal that you are entering/exiting program mode. The one beep from the remote lets you know that the remote has been programmed.
Dec 12, 2007 | Compaq HP Easy Access P/S2 Carbon/Silver...
990 And 950 Responder SST Remote - 7701P Logo
416 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
