Question about Refrigerators
How to Reset temperature in Big Horn Cold 1000
Contact the Dometic Customer Support Center at: 1-800-544-4881 or email CustomerSupportCenter@DometicUSA.com
and they can provide you with the reset for your Big Horn Cold 1000
http://www.dometic.com/enus/Americas/USA/Customer-Support/Contact/
http://www.dometic.com/enus/Americas/USA/RV-Products/Portable-Refrigerators/
Posted on Sep 09, 2010
I have a 1990 toyota celica when its cold the idle goes from bout 1000 to 2000 back and forth check engine light is on what cold its be or where should i start
Faulty engine temperature sensor ?? On a cold start the temperature sensor should detect a cold engine and give a signal to the ecu to increase fuel ratio until the engine has warmed up. sounds like faulty sensor to me.
Mar 02, 2015 | 1990 Toyota Celica
Iv got vauxhall zafria model 2004 outside temperature symbol is not coming on dashboard is that a big problem should take it straight to gargage
No outside temperature just shows the temperature outside the car the snowflake symbol will not show up until it is cold enough outside it has 2 stages yellow is an initial warning of cold temperatures when it gets to freezing the symbol will turn red.
The outside temp warning is not connected to anything mechanical only the engine temerature gauge is so dont worry it will not affect the running of the car but is just there as a warning of falling temperatures outside.
Feb 13, 2015 | Vauxhall Cars & Trucks
Horn blows by iteslf
No I haven't but if we think of how things do when they get cold, they contract and when they get warm they expand, do you think it could be contracting and pushing enough to cause it to make the circuit to make the horn operate when it gets cold. Just a thought of mine.
Nov 28, 2013 | 2005 Chevrolet Malibu
2000 Suzuki TL 1000 R Motorcycle my horn is not working
buy a new one, test with a light or voltage tester, oand if power has the horn got a nut on the front turn to tune it with button in
Aug 24, 2010 | 2000 Suzuki TL 1000 R
1998 cadillac, the horn just went off 3am in the morning, would not stop..until I pushed on the steering wheel part of the horn..car was locked..I had to get out of bed to stop it! WHY WOULD IT JUST GO...
I have a 1977 Cadillac Seville and it does the same thing, and when the outside temperature drops below 65 degrees the horn will sound continuously until either the horn relay or the horn fuse is removed.
The problem is in the horn pad on the steering wheel, and the contact plates inside of the horn pad are too close together (a manufacturing defect) and when the temperature drops down to a certain degree then the horn pad will contract and cause the metal contact plates inside of the horn pad to touch and make contact, and it is same thing as if you were pushing on the horn pad.
I have also heard of the exact opposite happening and when the temperature gets too hot the horn pad will expand and cause the metal contact plates to touch and make contact and activating the horn.
Jun 04, 2010 | 1998 Cadillac Seville
'01 GSXR 1000 won't start at temps above 170 or so.
Check the coolant sensor.Probably reads to the ECU that the engine is cold while it is not and the ECU injects more fuel that it should.Unscrew the coolant sensor (it is located on the cylinder head or on the thermostat casing) and boil it in water and measure it's resistance before (cold) and after boiling it (hot).It should not be the same.
May 25, 2009 | 2001 Suzuki GSX-R 1000
Fridge side cant keep 100 percent cold
Have you noticed a big difference lately in the cooling of the cold food section? Any time you open doors to a refrigerator or freezer you allow them to exchange room temperatures with inside ambient temperatures. The only time you should be concerned is when these temperatures begin to remain abnormally high. Many times the temperature rises in the kitchen while diner is prepared. Those temperatures also affect how long your refrigerator need to run to maintain the temperature settings you select. Your refrigerator has something called an Adaptive Defrost Control. If you should have problems with it you would notice a big difference.Another thing that can help is to make sure the condenser coils below refrigerator remain clean and clear of dust. The warm air circulating below your refrigerator is as important as the cold air inside. As for the vents that lead from freezer to cold food section they sometime become obstructed especially if they have a damper inside and frost locks the damper shut. If I missed something here please let me know, Thank You, Sea Breeze
May 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Weak sounding horn when cold
If you can remove the horn, spray some wd40 or other solvent into it and turn it so that the solvent will run into the center. Usually that will free it up. Or, just get another from a junkyard!
Jan 04, 2009 | 1996 Jeep Grand Cherokee
Heater not working
Heat adjuster door fix does not have to cost a lot of money. Search for Heater Treater. I lost dual control functionality but it is way better than the $1800 the dealer wanted to charge me.
Nov 01, 2008 | 2002 Jeep Grand Cherokee
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
