Question about Amana ARB2257C Bottom Freezer Refrigerator
Not making ice cubes - Amana ARB2257C Bottom Freezer Refrigerator
  • 5,081 Answers
Fill ice maker with tap water and let freeze. If ice dumps and water does not refill tray then the water control valve is defective. If ice remains in ice maker then ice maker is the problem.
I think Amana still uses the Whirlpool made ice maker. It consits of a mold, a paddel to remove the ice, a motor to drive the paddel and a cam. The electrical part consists of mold, thermostate or sensor ( use to be thermo-disc), micro switches, 1 to hold the unit running 2nd to alow water to flow at a certain time and a mold heater. Sequence of operation: Thermostate senses mold is cold, activates motor to turn paddels and cam. As cam turns it depresses a micro switch to hold motor running. Motor cam and paddel turn, mold heater is also turned on. As mold warms the paddels scoup out the ice. Contunes to turn until a spot on the cam activates another micro switch to allow water in. Motor continues, as cam reaches a spot it releases the micro switch for water andthen the switch holding the motor on and unit shuts off ready to do it again.
Posted on Sep 09, 2010
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
Ice cubes are too thin. Making on time, but no volume due to small cubes. What part will correct this?
Well this thing is made to make ice cubes so if the ice cube are to small thin then you water supply must be restricted because its cold enough to make the ice just the volume of water isn't their .Check the feed system for restrictions .
Jun 01, 2015 | Whirlpool Gold Series GI15NDXT 15"...
I cleaned the ice cube box & returned it to the RF20 Samsung fridge. Now it does not make ice cubes, Why?
Try re-seating the ice cub box, and make sure any ice maker moving parts, such as the ice bail wire are properly positioned and move freely. Sometimes the actuator and ice cube box do not line up correctly.
Make sure the ice cube box parts move freely.
Mar 11, 2015 | Samsung Refrigerators
Hoshizaki km151bah ice machine not making cubes. ice is coming out in one big sheet. Why?
The depth setting on the evaporator cube setting may be set too thick making the cubes stick together. Adjust it to make smaller cubes.
Feb 28, 2015 | Hoshizaki KM-151BAH 121 Pound...
What are flavored ice cubes?
Flavored ice cubes are a great way of jazzing up a drink and cooling it down without watering down the flavor in the way that regular ice cubes would. You can make fruit cubes or vanilla cubes and really add another dimension to your drinks.
Feb 18, 2013 | Home
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Mar 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Amana ARB2257C Bottom Freezer Refrigerator Logo
202 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
