Question about Whirlpool WED5520SQ Gas Dryer
I can hear ignter kick in at first dries for a few min. then goes cold no heat.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Heat will only heat for a few mins.
I would check the flame sensor and use steel wool clean the flame sensor or if you have a thermocoupler I would check that
Jan 21, 2018 | Heating & Cooling
Temp gauge stays cold
If the thermostat is bad (i.e. stuck open at all times), this would allow coolant to circulate in the engine even when it is below the desired operating temperature. This leads to OVERcooling of the engine. You can either replace the thermostat as a first step or remove it and test it -- closed when cold, open when heated above 190-200F.
Jan 30, 2014 | Chevrolet Malibu Cars & Trucks
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
I start time dry for 60 mins. It will run for
The heater element is not heating, they are fragile easy to get to at the back of the dryer. Check the thermal or overheat switch too, but would bet its the heater element.
Nov 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
It wont stay on high setting
take out of can or case, and thoroughly chemically clean with coil cleaning solution avail at Standard appliance, The foaming mild acid type is best! be careful it will burn you in a few mins if left on skin!
It goes on liquid and foams out the debris and chemically strips the surface for max heat transfer, If the evap coil is obstructed (as will happen quickly w/out filter) the sensor on your coil is turning off the comp as the coil isnt being loaded up with any heat load and it shuts off.
Make sure the air exiting the unit isnt obstructed or blowing into a closed area like garage or patio etc. if that doesnt do it adjust the sensor away from the coil just a bit and experiment. they all need to be cleaned as stated at least every other year min! to ever expect to work well.
Aug 25, 2009 | Fedders A6U10W7A Thru-Wall/Window Air...
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
Heat kick on then off
Check the thermostats. They work when cold but will not reset once warmed up.
Eric
May 27, 2009 | Kenmore Dryers
Dryer heats for only !st few mins.
there are different temp setting Thermostat ,check to make sure the right one was installed. recheck element continuity
Apr 09, 2009 | Dryers
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Furnace kicks on every 15 mins
fuanace may be oversized and is short cycling it heats up house to fast it is better when they run longer
Dec 06, 2008 | Honeywell Programmable Thermostat Heater
Whirlpool WED5520SQ Gas Dryer Logo
155 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
