Question about Whirlpool Duet GHW9150P Front Load Washer
At first it was flashing F then H. Now it is just trying to pump water out when there in none in it. Door lock and will not unlock.
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 09, 2010
My washer WFW70HE was started with the water shut off, now the door lock flashes, it sounds like the pump is running and none of the buttons including power will work. I have unplugged and re plugged?
Try resetting by pushing "Wash Temp", "Spin" and "Soil" buttons 3 times. Also be aware that your model may automatically run the drain pump for approximately 10 minutes when it is first plugged in. Let me know if you have success with that.
Apr 11, 2015 | Whirlpool Washing Machines
I have a brand new whirlpool wfw70hebw Duet washer that is stuck in the "draining" mode- the door is locked and the lock light is flashing red and it sounds like the drain pump is running. None of the...
I think you have a coin or something stuck in the drain pump itself. I have had to remove the pump,and take out the coin, reinstall it and it works perfect.
Jun 18, 2014 | Washing Machines
Looking for the speaker colors for a 2001 Jeep Grand Cherokee
Item Wire Color Polarity Wire Location
12V red & pink/black + ignition harness
STARTER yellow + ignition harness
IGNITION dk. blue + ignition harness
ACCESSORY red/black + ignition harness
SECOND ACCESSORY none
TACHOMETER *6 *6
POWER LOCK orn/blk - orn/pur *7 5wi door lock switches *1
POWER UNLOCK pnk/blk - pnk/pur *7 5wi door lock switches *1
PARKING LIGHTS + use (-) lights
PARKING LIGHTS - dk. blue/pink *2 steering column
DOOR TRIGGER *4 - *4
HEADLIGHTS yellow *3 at the headlight switch
WIPERS dk. green/red - steering column
LF WINDOW UP/DN lt. blue - white A drivers door lock switch
RF WINDOW UP/DN brown - purple A passengers door lock switch
LR WINDOW UP/DN dk. blue - red/wht B drivers kick panel
RR WINDOW UP/DN gray - dk. green B passengers kick panel
TRUNK/HATCH PIN tan/black - BCM, above diagnostic plug
HOOD PIN none
TRUNK/HATCH RELEASE none
FACTORY ALARM ARM arms with lock *7
FACTORY ALARM DISARM lt. green/orange *7 - *5
HORN TRIGGER gray/orange - steering column
BRAKE WIRE white/tan + drivers kick panel
LOCK MOTOR orange/black drivers door lock switch
UNLOCK MOTOR pink/black drivers door lock switch
DISARM DEFEAT pink/purple passenger kick panel
DISARM NO UNLOCK none
DOME SUPERVISION yellow/dk. green *7 - BCM, above diagnostic plug
SPEED SENSE white/orange PCM, passenger side firewall
SUN ROOF OPEN/CLOSE none
SUN ROOF LIMIT none
LF SPEAKER grn/orn - brn/red at the radio
RF SPEAKER purple - blu/pnk at the radio
LR SPEAKER wht/grn - grn/wht at the radio
RR SPEAKER grn/wht - blu/orn at the radio
RADIO 12V red/white at the radio
RADIO GROUND black at the radio
RADIO SWITCH white/red at the radio
RADIO ILLUMINATE none
POWER ANTENNA none
Notes: NOTE: Jeep vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Use orange/black and pink/black at the drivers door lock switch to lock and unlock the drivers door. Use orange/purple and pink/purple at the passengers door lock switch to lock and unlock all of the other doors. *2 The dk. blue/pink will flash the hazard lights. They will flash even with a latch input to the wire. The parking lights can be activated by using a 1300 ohm resistor to ground on the yellow headlight wire. *3 Use a 330 ohm resistor to ground for headlight activation. Use 80 ohms to ground on the same wire to operate both the headlights and parking lights. *4 There are 4 separate door triggers wire, one for each door. Use all 4 wires and diode isolate each together. The drivers door is tan/red at the drivers door lock switch. The passenger door is tan/red at the passengers door lock switch. The drivers rear door is tan/orange and the passengers rear door is tan/yellow at the BCM. WHEN USING A 455J INTERFACE MODULE, IT IS NOT NECESSARY TO USE THE SEPARATE TRIGGER WIRES. USE THE YELLOW WIRE AT THE UNDERDASH LIGHT FOR DOOR TRIGGER. *5 Factory alarm disarm requires a 463 ohm resistor to ground on the lt.green/orange wire at the drivers door lock switch, you MUST use a relay. *6 The 4.7L motor has a separate coil for each cylinder. Go to any coil and use any wire that is NOT dk. green/orange. On the 4.0L motor use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. green/orange. *7 Can also use DEI part number 455J door lock interface control module. This will control door lock, unlock, arm, disarm, dome light supervision and more.
Sep 26, 2011 | Car Audio & Video
Washer Flashing Error Code ND; door won't open after turning washer off
The ND error code means NO DRAIN. ,
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 23, 2011 | Maytag MAH8700A Front Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Water in tub and nothing happen when we try to wash cloths
usually this is indicitive of a bad pump or something stuck in it.these machines when first started they try to pump out first
the cycle will continue as long as it senses water
have them inspect the pump
good luck with sear service i hope it goes well
Oct 13, 2009 | GE WBVH6240F Front Load Washer
Door locks stoped working
See if there is a fuse for your door locks.
Good Luck!
Sep 15, 2009 | 2006 Chevrolet Tahoe
Kenmore Elite HE4t cycle time blinking but nothing happening
remove lower panel reach up to lock area and pull down on tab to release door remove as much water as possible go back to bottom and turn pump clean out to left HAVE PLENTY OF TOWELS HANDY..clean pump trap out and reinstall
Nov 09, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
