Question about Amana Refrigerators
Not making ice cubes - Amana Refrigerators
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
Ice cubes are too thin. Making on time, but no volume due to small cubes. What part will correct this?
Well this thing is made to make ice cubes so if the ice cube are to small thin then you water supply must be restricted because its cold enough to make the ice just the volume of water isn't their .Check the feed system for restrictions .
Jun 01, 2015 | Whirlpool Gold Series GI15NDXT 15"...
I cleaned the ice cube box & returned it to the RF20 Samsung fridge. Now it does not make ice cubes, Why?
Try re-seating the ice cub box, and make sure any ice maker moving parts, such as the ice bail wire are properly positioned and move freely. Sometimes the actuator and ice cube box do not line up correctly.
Make sure the ice cube box parts move freely.
Mar 11, 2015 | Samsung Refrigerators
Hoshizaki km151bah ice machine not making cubes. ice is coming out in one big sheet. Why?
The depth setting on the evaporator cube setting may be set too thick making the cubes stick together. Adjust it to make smaller cubes.
Feb 28, 2015 | Hoshizaki KM-151BAH 121 Pound...
My ice maker makes ice but melts fast
All ice is the same...at or below 32FH is ice, above 32FH it's water
Perhaps your ice maker is making very small ice cubes that melt faster then bigger ice cubes, if so the your ice maker needs to be adjusted too make bigger ice cubes.
Aug 10, 2014 | Scotsman DCE33PA1BC 15in Built-in...
What are flavored ice cubes?
Flavored ice cubes are a great way of jazzing up a drink and cooling it down without watering down the flavor in the way that regular ice cubes would. You can make fruit cubes or vanilla cubes and really add another dimension to your drinks.
Feb 18, 2013 | Home
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Mar 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Refrigerators Logo
49 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
