Question about Refrigerators
We have a imperial series refigerator. it stopped working this morning... sounds like fan is working, but nothing else
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
When furance kicks onafter a while the furnace stops working the range hood and the refigerater. after a while its starts working again.
It is difficult trying to understand what you are trying to convey to me. If you live in an older house, this may be the problem. Your furance, refigerator and range hood may all be on the same circuit. Your furance should have a dedicated circuit, nothing else on it. The refigerator should be on a dedicated circuit also, the range hood can be on a circuit with other devices. To find out what is on a curcuit, go to the panel and find the circuit that powers the fridge, have someone watch to see when the light goes off in the fridge, that will be the fridge circuit. Now check and see if anything else is off, eg. if the range hood doesn't work, then it is on the same circuit. If the furance fan will not operate then it is also on the same circuit. Do the same thing with the furance circuit, turn if off at the panel and see what else does not work.
Remember, the furance and the refigerator need to each have their own dedicated circuit.
Feb 21, 2015 | 2002 Bounder 39r
Why my condenser fan cuts on and off
That fridge should only run the condenser fan with the compressor running. If its cutting off with the compressor running, it's time to change the fan.
May 18, 2014 | Migali MFF-FR55ST Imperial Series...
Mr Kenmore refigerator started making a loud SNAP when the compressor starts and stops a while later. This apart from the fan noise. Relay?
Sounds like the compressor start relay might be the culprit. It generally clicks when the comp turns on or off but you normally do not hear it.
May 04, 2014 | Refrigerators
I have a imperial convection oven that I just purschase and operated fore 4 days, and the fan stoped working any idei what would cause this?
You don't say what model. Some Imperial ovens have a cool-down switch that lets the fan run with the doors open but not in cook mode. That is a starting point.
Mar 27, 2012 | Imperial Ovens
My magic refigerator/freezer condenser fan stops but when I move the fan blade it starts working and the refrigerator get cold again. Is it a bad fan unit or something else?
yes if you can barely touch blade and it stops the fan motor is bad. While replacing conderser fan motor be sure to clean dust from condenser coil.Then as regular maintiance clean coils twice per year.
Aug 12, 2011 | Refrigerators
Our Kenmore Refigerator was purchased July 1992. Model # 363-9524720 Serial # L220-16905. Problem: Refigerator runs but freezer section does not freeze and ice cubes are not forming. Food storage area does...
As a start, try cleaning the coils and fan under the refrigerator.
You would not believe how many refrigerators and freezers I've worked on which required nothing but a good coil cleaning. The dirtier these coils get, the less efficient the unit becomes until it reaches a point that it almost appears as if the refrigerant unit is not working at all when all it really needs is a good cleaning.
While you're under there, be sure the fan is running to pull air over the coils to cool and condense the freon inside them.
Sep 11, 2009 | Refrigerators
Our refigerator works on and off. Cools fine for a few days and then compressor stops. Wait 24 hours or so and then it works again.
Look under it for the cond fan to not be turning, find the condencer fan pulg it up and see if it comes on. If not she is bad and needs to be fixed, untill you can find a fan to fit. get a small fan from the store and aim it at the coil, clean the coil good so air can flow.
Sep 10, 2009 | Refrigerators
The blower fan stopped working this morning. No
You can take a look at your fuses and see if your fuse is burnt out or if that not the case and the fuses are fine then it sound like blower motor is shot.
Jun 27, 2009 | 2003 Honda Accord
My U-line under counter refigerator ice maker evap fan failed
Depends, for the newer models, you can change the evap fan motor thru the front, but if you have the older model, then you have to remove the freezer housing, ice maker assy then the cover to change the evap fan motor.
Nov 13, 2008 | U-Line COMBO29FF Origin Series...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
