Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I have a Philips 60 in. rear projection model# 60PP9020/17F made in sept. '04. There is a green arc across the bottom half of the screen. At the top everything lines up. I tried to use the multi point convergence but that made the bottom half of the screen arc(all colors). I've read a little on this site and seen similar problems and all the answers seem to be convergence kits. Is mine the same thing and how do I tell which ics I have. And where can I find parts for the t.v. Thank You
    Top Expert:
  • Philips Master
  • 14,553 Answers
As you look from the back the chips are on the board on the far left; black and each mounted side by side on metal plates with fins--this model should use 2 of the STK-392-120 CHIPS.
I buy mine on EBAY---select advanced search, search by seller---sewsales55 is the seller I use. This is Suburban Electronics in Maryland (they also have a online catalog) and a pair of the chips should cost under 15 dollars from them.
If this helped, rate this solution as very helpful as I do this here for free.
SD TECH
See typical convergence problems:
Posted on Sep 09, 2010
Testimonial: "Thank you for answering my questions and I think that you have given me the information i need to fully repair my t.v. Thank you again!"
Picture blury and stretched
You have bad convergence ICs, requires disassembly and soldering to replace, quan (2) stk392-120 can use 150s or stk394-160 also.
they are located on the SSM CBA facing back left side, many delicate cables , torx 10 screws also look for any discolored 6.8ohm resistors near the ICs, usually (2) burnt resistors. most shops charge around $300 for the job done in house. Also will need to check that the yoke aren't loose and tilted (philips had black tape on some). and you may need a fluid change by now on the Blue and green CRTs (a professional job for sure). good luck !
Eric
Jul 31, 2009 | Philips 60PP9202 60" Rear Projection...
The scroll on the top of the screen is arced
Convergence IC's are bad. You can get the parts over the inernet or you can get a complete kit - parts - instructions - etc from www.TvRepairKits.com
May 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
YOU CANN GREEN AND PINK SEPERATE
my t.v. turns off and on whatis the problem
Jan 28, 2009 | Philips 60P8341 60" Rear Projection...
Arcs at the Top and Bottom of the screen!
You will find small 1/2 or 1watt resistors close to the ic's, you must measure them and they must be exact ohms. I believe you'll find a couple open or have changed in value, I hope the new Ic's haven't been fatigued. That should fix your problem.
Jan 19, 2009 | Philips 60PP9202 60" Rear Projection...
Projection tv philips model number 60pp9202/17f
that sounds like the classic symptom of the convrgence Ics needing to be replaced they are STK392-120 you can get both replacement ICs at the following link with free instalation instructions. here is the link.
http://servicemanuals.vstore.ca/
Jul 07, 2008 | Philips 60PP9202 60" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
618 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
