Question about Refrigerators
Manual for a lg electrocool fridge - Refrigerators
  • 400 Answers
SOURCE: LG GR-292R freezer works/fridge does not.
It is more than likely short of refrigerant, needs to have the leak repaired and then recharge refrigerant.
Posted on Mar 05, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: How can I switch the door from left opening to
Look at the top and bottom of the door. There should be two holes near the edge. If there is then you just remove the hinges by the screws and place them on the other side of the fridge and flip the door over. At that point your shelves should be able to be flipped also. But if the manual does not say anything then your doors may not be able to be switched
Posted on Jan 02, 2010
SOURCE: i have electrocool LG MOdel# GR-382R ser#
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Posted on Jan 07, 2011
SOURCE: I NEED TO SWOP THE
Hi there, you don't state the model number in your post but if you go to this link
http://www.lg.com/us/support/product/support-product.jsp and select the help by chat icon on the top left I am sure you will be able to get LG to email you a copy.
Posted on May 04, 2011
caroldon
  • 17130 Answers
SOURCE: LG electrocool fridge - serial
Please check the link :
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Posted on Jul 19, 2011
I have LG Electrocool GR-252SQ(Double door).the freezer is very cool but the lower fridge section is not getting cool.Plz guide.
i have same fridge and my problem is that the water from freezer is not going out pf the fridge, instead it comes down to fridge section through condensation
Mar 24, 2013 | Refrigerators
LG electrocool fridge - serial no. 407KRXD00074; the frost free freezer has a huge ice build up, please assist. im also trying to find the manual book for the fridge.
Jul 19, 2011 | Refrigerators
I NEED TO SWOP THE FRIDGE AND FREEZER DOORS OF MY LG ELECTROCOOL REFRIGIRATOR TO OPEN FROM RIGHT TO LEFT BUT CAN'T FIND THE INSTRUCTIONS MANUAL. WHERE CAN I DOWNLOAD A MANUAL?
May 04, 2011 | Refrigerators
How can I switch the door from left opening to right opening on an LG electrocool (top) fridge (bottom) freezer? The user manual says nothing about it.
Jan 02, 2010 | LG (LRBC22522ST) Stainless Steel
Fridge gets cold then shuts off
Feel the motor temp. after letting it do its thing for a reasonable period. If motor is extreemly hot then it means motor is switching off on internal protection.(has to be replaced then.). Set temp to its coldest then see if it still switches off as it is. if the same, board is more likely to be a problem. Very seldom if ever does one have to replave sensors. (assuming it has an electronic board). If using a th/stat, replace it if temp does improve but still eratic.
Sep 16, 2009 | LG Refrigerators
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
Thanks.
Jun 22, 2009 | LG Refrigerators
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Refrigerators Logo
459 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
