Newdlpbulbworkedfineforthreedaysnowwillnotlightup. old bulb will
  • 10,594 Answers
New dlp bulb worked fine for three days now will not lightup. old bulb will.
Let me know model number and brand of your tv to provide you helpful info about possible cause of problem.
Thanks.
Posted on Sep 09, 2010
How do I replace light bulbs in a Bernina sewing machine model 1080?
Check the bulb model number old versus new and make sure you have the same number bulb. The bulb number should be on the base of the bulb somewhere. If the bulb has tabs sticking out of the base, check to see that they are placed such that both tabs are on the same plane on the bulb base. Some bulbs have offset tabs that only go in one way to the socket. Try rotating the bulb 180 degrees and insert it again to the socket before trying to rotate it. Check your manual for bulb replacement procedure. Make sure also that you didn't rotate the glass bulb out of its base when you pulled the old one out, leaving the old base still stuck in the bulb socket. If this is the case, unplug the machine and use needle-nose pliers to remove the old bulb base before trying to replace the bulb.
Jan 14, 2015 | Bernina Sewing Machines
No light in door dispenser
The light bulb is located in the top panel just above the dispenser and to the front. Be sure to check the manual for bulb voltage, most of these used a 12 volt bulb and NOT a 115 volt. It looks like an old style small base Christmas tree bulb.
Mar 21, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Replace heater control panel bulbs
1. use old bulbs as samples by gently removing them with a soft cloth.2. Go to autopart shop or walmart,target or Canadian tire and you will find replacement bulbs. 3. Make sure you mark or place each old bulb into an envelope so you know where to put the new bulbs.
Jul 17, 2013 | Nissan Cars & Trucks
I need to change the primer bulb on the ryobi 790r weed eater. How do you get the old one off and the new on.
Remove fasteners on bulb plate, lift, remove old bulb install new bulb, fasten plate.
Aug 25, 2011 | Garden
How to change headlight bulb on 2007 nissan maxima
If you open the hood and look down behind the headlights, you will see a socket where the wires come in. Turn it counter clockwise and the bulb should pull out. Replace the bulb and reverse the process.
Mar 01, 2011 | 2007 Nissan Maxima 3.5 Sl Sedan
How do i cahnge my front headlight bulb
It is fairly simple to change your headlight bulb. First you need to buy a replacement bulb - typically the auto store will have a catalog with different models for your bulb. (Different brightness usually) My replacement bulb had the model 9004.
DO NOT TOUCH THE GLASS OF THE BULB WITH YOUR HANDS - the oil on your hands will cause the halogen bulb to burn out faster. You should be able to handle just the plastic part in the rear of the bulb.
Remove the old bulb (at the back of the headlight assembly) by twisting off the circular "cap" that keeps the bulb in. You can then detach the bulb socket and remove the old bulb. Insert the new bulb carefully and attach the bulb socket. Then twist the cap back on.
Oct 28, 2010 | 1997 Nissan Maxima
HL-R5656W Unit made loud pop and pic went black, ordered bulb but there is a loud crackling with some flashing going on when I re-inserted old bulb, is this the ballast that needs replaced?
Wait until you get the new bulb to determine that. The old bulb is probably arching as it tries to start.90% of the time the new bulb will do the trick.
Oct 31, 2009 | Samsung HL-R5656W 56" DLP HDTV
I have a ford taurus 95 and the passenger brake lite and blinker is not working but when u put the lites on the bulbs work but still no brake lite and blinker
You most likely need a new bulb in that location.
It is a dual filament bulb......one filament for the brake and signal and one for the running light ....both in the same bulb.
Remove the old bulb and get a replacement bulb using the # printed on the old bulb.
Oct 14, 2009 | 1995 Ford Taurus
How do you replace aheadlight light bulb ina olds
Remove plastic Grill (6 screws)
Remove Turn Signal Light (3 Screws)
This allows you to access the 4 screws that hold in the Headlight. Remove these and then remove the headlight. Once out, then just turn the bulb and remove. Be careful with the plastic clip that holds the bulb to the wiring harness. Since the car is old, the plastic will easily break.
Sep 20, 2009 | 1989 Oldsmobile Cutlass Ciera
Broken screw of Light bulb stuck in Neff Oven
hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Jun 29, 2009 | Neff B1421 Electric Single Oven
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
