Question about D-Link Xtreme N DIR-655 Wireless Router
Every time I try to establish a VPN through this router with my work laptop, the internet connection will hang for a couple moments, and then the connection from the router to all devices connected to it will go down for several seconds. This process happens every time I try to set up a VPN using a Cisco VPN client installed on the laptop. Why does this happen?
  • jdriscol Sep 13, 2010
    Actually, the firmware on my router is current, and I had already reset it a couple times, and that hasn't fixed the problem.
  • D-Link Master
  • 6,487 Answers
Base from the description of your problem this issue has something to do with the firmware of your router, so to correct the problem do a firmware upgrade on your router or if there's no updated firmware you just flash the firmware to it then check if the problem is already fix after doing that.
Posted on Sep 09, 2010
Need to hard reset my WAG200G to connect to VPN
You will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.
Jul 27, 2012 | Linksys Wag200g Wireless-g Adsl Gateway...
Hello i have a problem with Archos 5 Internet tablet... our isp give me a ip adress And Vpn connection & i can connect with laptop but in archos i connect to wireless access point but i can't...
Hi, Unfortunatly there is no solution with your current set up, you will need a medium grade router like a draytek 2820, that can establish the vpn from itself rather than from the computer, this way the vpn is established from the router, and when your archos connects to the router it will also have access to the vpn.
Jun 02, 2011 | Computers & Internet
Cannot link vpn. direct from internet provider works. when try connection via d-link dir625 does not connect. does allow internet access
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
Feb 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have a motorola wireless router and VPN will not establish a connection. I can access the internet, but no VPN
For VPN, you will have to open specific ports in your router . See this link..for what ports have to be opened.
http://www.speedguide.net/faq_in_q.php?category=102&qid=163
To open the ports, you have to go to the webinterface of the router .
Hope this helps
Thanks Ranjit
Nov 03, 2009 | Arris SURFboard SBG900 Wireless Router...
Trying to set up a vpn server on windows XP using
Did you already forward port 1723? I guess you have done that. To isolate it, try to bypass the router and setup or establish the VPN session there. If it doesn't work, maybe your ISP doesn't allow port 1723 or it's just the modem.
Oct 22, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Unable to connect VPN using Arris Modem & Comcast Router
hi, mate check firewall settings of your modem/router. Then contact your IT administrator and he should be able to make changes to configurations for you. In most cases if server classify's your connection as unsafe it rejects it.
Jul 17, 2009 | Computers & Internet
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to rabih_2@hotmail.com
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
I can't connect through the VPN and Internet at the same time
when you have 2 connections open at the same time you need to tell the computer which one you want to use to connect to the internet. the way to do this depends on the operating system but in windows the setting is in advanced properties of the network connection in control panel
Jan 21, 2009 | Belkin Wireless Cable/DSL Gateway Router
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Cannot connect to internet on my laptop with linksis router
do you check the interface up.
do you check the protocol up .
do you have a signale untell your router before connect it
abanda741@yahoo.com
Dec 04, 2007 | Computers & Internet
D-Link Xtreme N  DIR-655 Wireless Router Logo
185 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
