Question about Canon IMAGERUNNER 6570 Copier
E00100 - Canon IMAGERUNNER 6570 Copier
Sir
first u change your thermistor after again restart machine
Posted on Jun 01, 2015
  • Canon Expert
  • 1,326 Answers
A E00100 means you have a laser problem. You may have a bad laser? Also, I would make sure the cover for the Primary charge is on correctly. There is a lever that gets pushed in to turn the laser "ON"
Posted on Sep 09, 2010
What does filesys error e00100 mean
Hello and Welcome to FixYa!
Error e00100 means that the card is corrupted or formatted for another digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't work The Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card,
I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Kodak EasyShare C310 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
Hi ,Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    Trouble Formatting New SD card
    try to format using a card reader through PC...
    Feb 10, 2009 | Kodak EasyShare V803 Digital Camera
    Easysharec310
    try using a 1gb card...that is i believe the most it supports
    Jan 14, 2009 | Kodak EasyShare C310 Digital Camera
    FILESYS ERROR e00100 2.0GB PNY technologies
    try formating
    u get warranty on this and hence approach the point of sales
    Jul 01, 2008 | PNY 2GB microSD Memory Card
    807 people viewed this question
    old marine
    old marine
